Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Clutch slipping after trip at glasshouse, new HD NPC clutch.
    Oct 2017
    Hey guys just got my patrol back this week it was converted from a 3L to a TD42 Factory T Blacktop (2001 GU Manual) with a few goodies. One of those goodies is the HD NPC Clutch.
    Today I was out at Glass House Mountains having a play, It wasn't my intention but I ended up slipping into a bog hole and I believe the box would have been mostly submerged for a good few minutes. After getting pulled out, I continued 4x4ing (away from bogholes) for probably 3 hours having a blast with no issues at all. It wasn't until going back to 2wd and jumping back onto the roads that I realized what feels to be the clutch slipping. It doesn't really slip in 1st but if you give it a bootfull in any other gear it just starts slipping, it catches back on pretty fast but obviously it's not right. The pedal is also feeling sticky now, it wasn't feeling sticky while I was out Just wanted to hear peoples thoughts and possibilities. Cheers
    Stick a hose under the clutch fork boot and wash the clutch out. The sticky feeling is the thrust bearing carrier sticking on the nose cone of the gearbox due to the mud in there.
    Oct 2017
    Im assuming the clutch fork boot is going to be located somewhere near the bellhousing? I'll have a look in the morning mate thanks, should I pull the boot off or just try and wash it out as best as I can as it is
    LHS mate where the clutch slave cylinder is. Im guessing this is where the mud got in too. Before you wash it out make sure there is a drain plug at the bottom to let all the crud out. If not. You might have to make one.
    Rossco (11th October 2020)
    Oct 2017
    I will have a look in the morning and update you with how I go
    Oct 2017
    Hey mate just had a look and you're right it is full of mud. I can see gaps in the middle of the boot its almost like it's too big and it squishes in either side in the middle. I just pulled it out a bit and pulled a few chunks of sloppy mud out.
    Would it be safe to just put the hose into the boot and have it all come running out the other side where the gap is ? or i could just leave it hanging out and put the hose up in there
  9. #7
    Quote Originally Posted by Jdugg27 View Post
    Wheres the gap on the other side you mention? The only hole in the bell housing should only be where the clutch fork is.
  10. #8
    Oct 2017
    [QUOTE=mudski;810499]Wheres the gap on the other side you mention? The only hole in the bell housing should only be where the clutch fork is.
    The gap is on the clutch fork boot, the rubber has a gap in the middle which allowed mud in. After washing it out i didnt have drive for a few minutes let is sit and went again and now shes going mint
  11. #9
    Is the water and mud able to drain out?
  12. #10
    192 Post(s)
    Yeah they will never seal water out (being submerged anyway) the way they are from factory. Good idea to silcone the fork boot both ends (bell housing & where the fork goes) and also silicone in the bung on the bottom of the bellhousing. If you remember it's good measure to pull out bung every service or so to check rear main isn't leaking and no water has got in.
