5th May 2012, 09:16 PM
Td42 runs on after shut down
Old girl tends to run on after shutdown would i be rite in thinkin that its the pump timing?
The Following User Says Thank You to Dave.79 For This Useful Post:
5th May 2012 09:16 PM
5th May 2012, 09:56 PM
There is a few causes for this. Pump timing as you already said. The fuel cut solenoid or the other one is if the springs are a little soft in your injectors.
6th May 2012, 10:43 AM
6th May 2012, 11:11 AM
Hey mate, i just had the pump and injectors replaced so im thinkin i can rule out pump timing and injectors ...privided its all set up rite..
7th May 2012, 10:22 AM
Double check timing. Did they replace the fuel cut solenoid when you got your pump rebuilt.
10th May 2012, 06:10 PM
I had this issue in my old petrol hilux it turned out to be heat soak through to the carby so fitted a new gasket which stopped it, can't remember what it was made of sorry.
GQ Snorkle Lockers front n rear
The Following User Says Thank You to 89gqpatrol4x4 For This Useful Post:
13th May 2012, 06:00 PM
What do you call run on. A big shudder when you turn it off, or does it run for a few seconds?
Mark
13th May 2012, 06:49 PM
G'day Mark,
Big shudder after shut down means the starter motor right???
14th May 2012, 06:57 PM
Ummm??? Not sure I follow?
Mark
15th May 2012, 11:54 AM
Diesel run on. The engine turns over for to long after shut down. Mine still does it occasionally But only every once in a while and only for an extra turn at the most.
I would try and retard the timing and see what happens. Just a little bit at a time.
