Page 892 of 1049 FirstFirst ... 392792842882890891892893894902942992 ... LastLast
Results 8,911 to 8,920 of 10488
  1. #8911
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Yeah I lost the E-Clip off the turbo actuator rod to lever pin the other day, even had some fishing line attached to it but it twanged out of the noose. No where to be found and all I could buy was a C-Clip that I had to squeeze to get it stay on. Looked all over and waved my magnetic flex stick no joy, then yesterday found it while vacuuming up swarf, sitting on rubber wheel arch apron. So easy when I could see it and was amazed it did not get sucked away.
    Still tied up secure.
    Phil, post up a link for the Turbo timer.
    194 Post(s)
    Here you go. Factory set at 30 secs delay but can extend out to 5 mins in stages.
    https://www.ebay.com.au/itm/BOGAARD-...72.m2749.l2649
    I also lost a 13mm spanner for 9 months under the truck, fell down and disappeared, was caught between a hose and the chassis, and only found it when replacing the hose!
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    Bidja (7th February 2019)
  5. #8913
    472 Post(s)
    Ran it out of diesel on the Calder Hwy-Catlemaine towing the Kanga, what a nuffy MB :-(
    Boys in the slow truck 30 mins behind me pissing themselves and bringing a jerry :-)
  6. The Following 3 Users Say Thank You to MB For This Useful Post:
    AB (7th February 2019), Avo (9th February 2019), PeeBee (7th February 2019)
  7. #8914
    581 Post(s)
    Pop the plunger plug mb and pump it through before starting mate.
  8. The Following User Says Thank You to AB For This Useful Post:
    MB (7th February 2019)
  9. #8915
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Installed the Redarc towpro elite v3 (the v2 was the recall)
    Hope to pick up a camper trailer next week.
  10. #8916
    194 Post(s)
    Installed new 30um filter and lift pump for the s/c, what a mission. AT it 8 hours, installed between the rear of the rear axle- clear - and the long range rear tank. Its getting tight back there now with the belly tank transfer pump and pre-filter. Dirty day tomorrow hooking it up, then wiring the lift pump.
    Also modified the rear coil tower bridge plate after lifting the vehicle 25mm. Getting that back in was also a treat - NOT. Had it remove everything in the rear to get to the bolts, and surprise surprise, vehicle popped up and jammed under the garage door!. Had to drop pressures to 10psi and dump 3 batteries in the back just get back out - this is a problem for sure. Also noticed a broken 'stay' under the car which must have broke when the body was jacked up - unsure what its for but it now has a 25mm airgap and and broken bolt. Its towards the centre of the car behind the rear seat. Once I get everything sorted I will take a photo and share.
    mudnut (9th February 2019)
  12. #8917
    WA Wheatbelt
    23 Post(s)
    Saw my ute sitting in the driveway, pondering what to do with it! Sad, very sad.
  13. #8918
    109 Post(s)
    Take it for a drive. Fall in love again mate. Mine doesnt get used like it used to and had the sell thoughts going through my mind also. Did a small trip in it and fell in love again! Cmon yours is a trophy winner!
  14. The Following User Says Thank You to Plasnart For This Useful Post:
    DX grunt (9th February 2019)
  15. #8919
    WA Wheatbelt
    23 Post(s)
    Thanks. I really don't want to get rid of it! I still wash and clean it. lol
  16. #8920
    Yeah boi
