15th December 2018, 09:39 PM
Where do I put my EGT prob on my high mount ?
Here is my shiny new toys and I am glad that I didn't plum up my intercooler before I got my turbo because the intake snail is in the completely different spot,only problem is the pipes were stainless steel, anyway back to my original question were do I put my EGT prob I want it pre turbo and the turbo sits on the forth exhaust pulse on the exhaust header
15th December 2018 09:39 PM
15th December 2018, 09:46 PM
Hey mate, what turbo & pump did you go? Depending in turbo should be able to rotate the housing to move the outlet to suit. Most put probe in dump pipe just weld a bung in but can go in the manifold too.
15th December 2018, 09:55 PM
Thanks bro I know you can rotate the snail but I think where it is now is a better position the befor plus the out let would hit the wast gate bracket if I spun it around, and I was told the pre turbo gives a more accurate reading and I want for nothing but the best UFI 21L turbo and a 12 mm 250 hp ip
The Following User Says Thank You to First Pooy For This Useful Post:
Rossco (15th December 2018)
15th December 2018, 10:02 PM
Hey mate, nice. Have just put same pump on mine and impressed is in understatenent lol. Haven't even put my foot all the way to the floor yet lol just cruise around on a 10th throttle just delivers. Closer to motor is better but nothing wrong with dump pipe i reckon.
15th December 2018, 10:10 PM
Hey FP, that battery is extremely close to the turbo - its going to cook in no time. Are you moving it - so tight I think even an insulated box isn't going to work so well. Also, note its an AGM, its not going to like the under bonnet heat at all, would be bad enough if a wet cell. I would say move it before you kill it.
15th December 2018, 10:43 PM
That is going to be a problem I have no where else to but the battery I have so much stuff in the back that space is an issue
15th December 2018, 10:46 PM
First Pooy
You have a choice, leave it and destroy it, or move it and save it!!!! I assume it can be laid on its side being an AGM, so maybe that opens up some options.
15th December 2018, 11:04 PM
#8
PeeBee
I could possibly chang the start battery and the AGM around and swap places what do you think so then it would be on the intake side away from the turbo heat
16th December 2018, 11:08 AM
#9
This is a compromise that will still see the battery cook, even if a wet cell. The only advantage of swapping the wet cell location is that you can top it up, and you will be doing that frequently. Only takes one time you forget and it's over. Honestly, spend the time, go the extra yards and remove the battery from that location, you will be better off for sure unless you own a battery store.
Hodge (16th December 2018)
16th December 2018, 11:25 AM
#10
I'll agree with PeeBee on this one.
If you have any chance of putting the battery somewhere else, it'll be better for it. I know most setups have the battery sitting under the hood and some last for ages without any dramas. But slow cooking your battery isn't good. My battery got heat damaged and that was the end of that. Sitting inches from the turbo, it was only a matter of time. And now I have so much room there i love it, especially with the larger turbo and intake coming up... So glad i did it.
Slotted the aux in the rear and happy now.
The Following User Says Thank You to Hodge For This Useful Post:
PeeBee (16th December 2018)
