29th May 2020, 05:21 PM
#351
jay see
Cheers gents.
I dropped in to my local workwear today. The had all the named brands. I've had Oliver, redback and Blundstone in the past and found them all to be good. I took the reps advice and tired something different. Steel Blue. Will see how they go.
Steel Blue = awesome. Used to get sore feet before I found them. On my 3 rd pair.
The Following User Says Thank You to Mickhead For This Useful Post:
29th May 2020 05:21 PM
30th May 2020, 07:29 PM
#352
jay see
Not tool related but close. Work boots..
I'm due for a new pair and unsure what to get.
I'm looking at the $150-200 range.
Steel Blue, mongrel, cat is there much difference between them all?
I know that everyone says that they want a comfortable boot, but I really do mean it.
Nuff said!
The Following 5 Users Say Thank You to mudski For This Useful Post:
jay see (30th May 2020), Mickhead (1st June 2020), Plasnart (31st May 2020), Rossco (30th May 2020), rusty_nail (31st May 2020)
31st May 2020, 09:40 AM
#353
Thongs! Double-pluggers if safety is an issue.
The Following 2 Users Say Thank You to Brissieboy For This Useful Post:
mudski (2nd June 2020), Plasnart (31st May 2020)
1st June 2020, 01:06 PM
#354
10G
Thanks for the info Daz, much appreciated.
I went forked out $69 for one of those Hercules 12v wrenches, I reckon it'll do what I want & if it doesn't well I'll worry about that then.
Sounds like from what you said that the driver may be the way to go, the type of work I'd do would be lighter stuff so the driver may be a more appropriate option.
Thanks everyone.
Wrench turned up today, gotta be happy with that service, ordered on Thursday, turns up lunch time Monday in rural Vic.
Not opened it up yet, will later on.
1st June 2020, 04:02 PM
#355
Bought one of these 'reluctantly as its probably going to be used once every 20000yrs. Need it right now to drill out a snapped stud in the block tomorrow, simply could not do it any other way due to clearance issues, or had to remove the radiator. have a pile of batteries i use for my chainsaw, so that worked. I suppose if I put it into a shop to have them do it it would have been twice the cost of the tool.drill.JPG
rusty_nail (1st June 2020)
1st June 2020, 04:16 PM
#356
Gee I've had a few uses for something like that over the years. Will it be out of warranty in 20000 years?
The Following User Says Thank You to 10G For This Useful Post:
1st June 2020, 05:56 PM
#357
Daily Lurker
PeeBee
How's it going mate? They are an awesome tool but with very limited purposes. Often wanted one for cabinet making etc but have always gone the tightass drill adapter approach, they are about $300 right?
1st June 2020, 06:09 PM
#358
Yes Nic, on the shelf at Total tools for $298, but got it for $270. I have the chuck 90 deg adapter, but they are a bit weak. I have a 100% metal one I found some time ago, but it still is longer in the snout than this one. I am hoping its going to make the stub removal easier tomorrow.
1st June 2020, 06:34 PM
#359
PeeBee
Is the bolt broken below the surface of the thread?
If it's not then just weld a nut to it and undo it. Even if its snapped flush you can still weld something to it.
MudRunnerTD (1st June 2020)
1st June 2020, 06:35 PM
#360
Moderator
PeeBee
Nice, i have one is a Corded version which i did a Heap of work with back in the day. generally only used it as a Screw gun though for a specific product in my range. It has been handy for the odd hole though over the years for sure. Could not justify an 18v one these days and you are right it will be used little. The guy that built my shed had one and he used it for tek screws in confined spaces and it worked great. Up against the fence for the boxing for the concreter was also handy.
Check out my Toy -->
Rogue Dung Beetle
