Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 71
Thread: TD42 Compression Test Results Query Please Team
  1. #31
    North brissy
    Will always have fumes. But the filler cap isn't even bouncing around so looks good.
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    MB (29th June 2021)
    192 Post(s)
    Yeah nothing to worry about there for sure. .
    . . Looks like I feature a fair bit on your channel, might have to start paying royalties. .
  5. The Following 3 Users Say Thank You to Rossco For This Useful Post:
    Hodge (29th June 2021), MB (29th June 2021), rusty_nail (29th June 2021)
  6. #33
    472 Post(s)
    Thanks Gents, Appreciated
    I just need to alter all of the names slightly @Wossco and they’re legally mine…….forever
  7. The Following User Says Thank You to MB For This Useful Post:
    Rossco (29th June 2021)
  8. #34
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    What are your thoughts on fitting a lift pump to help the tired IP a bit..?
    John
  9. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    MB (29th June 2021), mudski (29th June 2021)
  10. #35
    461 Post(s)
    My thoughts exactly whilst driving home from work today. Run a Carter 4600, or whatever number they’re up too, just after the fuel tank.
  11. The Following 2 Users Say Thank You to mudski For This Useful Post:
    jff45 (29th June 2021), MB (29th June 2021)
  12. #36
    472 Post(s)
    That sounds great to be honest John Mate
    Have you any recommendations on brands possibly used yourself before and happy with?
  13. #37
    472 Post(s)
    Thanks Mudski Mate
    Was typing same time, Carter sounds good
  14. #38
    Morayfield, QLD
    13 Post(s)
    I run a Carter 4600 that I bought from @mudski years ago. It uses the old TB45E ECU “prime” function to run for 5 seconds on ignition, which is basically while the glow is happening, then switches on full time once oil pressure is established.
    If engine stalls and oil pressure drops, the pump just stops.
    Some command it from the alternator to have a similar cutout feature if engine stops for whatever reason.
    John
  15. The Following User Says Thank You to jff45 For This Useful Post:
    MB (29th June 2021)
  16. #39
    472 Post(s)
    Was just reading up on some other very helpful advice from Mr Mudski on here too thanks John
    https://r.tapatalk.com/shareLink/top...ink_source=app
    @mudski Mr Mark are you still running the business on the side Mate?
  17. #40
    461 Post(s)
    No I sold that business mate. To my current boss's son in law. Lol.
    Anyway, the Carter is still going strong. I have it plumbed in with a bypass set up so if the pump fails fuel will be drawn via the bypass and not through the pump which may have adverse affects. I also have it wired in so the pump only runs when there is oil pressure, so the earth for the pump is connected to the oil pressure switch. Some will wire it straight via the ignition, so they can prime a new fuel filter easier, but I don't like the idea of the pump, pumping fuel when its not needed, say like if your doing some eleccy work and need the ignition on etc. Its not hard to pump the factory primer anyway. My setup runs its own relay aswell. No biggie either way with this, personal choice really...
  18. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (29th June 2021), Rossco (29th June 2021)
