Results 1 to 7 of 7
Thread: Safari Central door lock
    Sep 2022
    Guam
    24v Safari all window switches work but the central locking button doesn't. any suggestions on a fix? I don't mind manually locking but the wife always forgets to lock her door. So it would be nice to find a fix.
    Apr 2021
    Brazil
    Is the problem on the lock button on the drivers door alone or on the door actuators? For instance, if you take the wires from the lock button and short them yourself, do the central lock operates and locks all the doors?
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    i'd pull the door switch and even the master actuator (drivers door) hose all the connections with marine grade CRC and see if that makes a difference.
    otherwise it will be a matter of following the wires to find out what works and what doesn't
    1989 LWB 5-Seat, TD42
    Apr 2021
    Brazil
    Quote Originally Posted by mihit View Post
    marine grade CRC
    What is that mate?
    Sep 2022
    Guam
    I'll have to pull the door card off soon to verify. Haven't had the best of luck with 24v systems so far. Mostly because I've never dealt with it and just assumed everything would work lol.
    1992 24v Safari high roof Td42
    1994 Subaru Impreza WRX wagon
    2020 Subaru Forester
    2019 Subaru Ascent.
    What is that mate?
    Sort of like WD40 but marine grade.
  8. The Following User Says Thank You to mudnut For This Useful Post:
    BrazilianY60 (21st December 2022)
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    What is that mate?
    Used to be sold as CRC66
    Now, at least in NZ, it's called "CRC 5,56 Marine". Probably dolphin-friendly, removed all the potent ingredients. Still good stuff though.
    https://www.crc.co.nz/Marine-66/6891...-52a64c4520ea/
    ...It just occurs to me that it's an NZ company, so might be unknown overseas. Similar no Inox? It's better than WD40... probably equivalent to a mix of sewing machine oil, acetone, mild acid, and diesel.
  10. The Following User Says Thank You to mihit For This Useful Post:
    MB (24th December 2022)
