Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 69
Thread: GUII heater core replacement
  1. #21
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Well here’s an interesting twist. I’ve just looked up under my dash with a mirror and lo and behold i have no tap on my heater core. The 2 ally pipes are clearly visible.
    The Partsouq catalogue is wrong for my VIN.
    John
    461 Post(s)
    Mark, just to clarify, yours is 8/2001 and it already had the heater core with no tap?
    Correct...
  4. #23
    461 Post(s)
    I have the Nissanfast Program on my laptop at home. I could check that for you if you like.
  5. #24
    Morayfield, QLD
    13 Post(s)
    Thanks but no need mate, I can easily see up under the dash that there’s no tap. Don’t know why I didn’t think to look before then it occurred to me the other day that I have a little BT borescope that might show something but tried first with a mirror and torch and surprised to see it no problem.
    I’ve decided to start taking it all apart tomorrow morning..
    John
  6. #25
    175 Post(s)
    John. Could you lay out out in laymans terms to the nuffy rest of us what this tap is all about?
    As mentioned earlier, I hope i do not ever need to endeavour this task. But would like to arm my self with facts if need arises.
    Also...
    I LOVE you how casually state that theres a chunky full bellied carpet snoring above your work area and go about your business lol. Most inhumans around here would run to the next suburb or grab the first sharpest objects they'd get their hands on.
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Also...
    Carpet snakes/pythons are a farmers best friends. I lived on a farm for more than half of my life. When we found a carpet, we put them in the hay shed - great for keeping rats and mice under control (as long as there wasn't a plague of the pesky little rodents). Often found skins as we used up the bails of hay but didn't see the snakes too often.
  8. The Following User Says Thank You to Brissieboy For This Useful Post:
    Hodge (18th June 2021)
  9. #27
    Morayfield, QLD
    13 Post(s)
    Also...
    I doubt your later model would have the tap. It appears to be something Nissan added to the early GUs and was actioned by the mixer flap - the flap that controls how much air goes through the heater core.
    Most info I’ve read isn’t very accurate about when the tap was discontinued.
    If you get a mirror and torch you can easily see what you have.
    Couple of not very good pics here to show the heater box with and without the tap. In the pic with the tap you can see the rod that connects to the pivot of the mixer flap and you can see the mixer flap slightly open
    John
  10. The Following User Says Thank You to jff45 For This Useful Post:
  11. #28
    Morayfield, QLD
    13 Post(s)
    He decided to move this morning..
    John
  12. The Following 4 Users Say Thank You to jff45 For This Useful Post:
    Hodge (18th June 2021), MB (18th June 2021), mudski (18th June 2021), Touses (18th June 2021)
  13. #29
    175 Post(s)
    I love em.
    Helped a snake catcher mate out for a while , but never had a chance to meet a python in the wild being in Vic.
  14. The Following User Says Thank You to Hodge For This Useful Post:
    MB (19th June 2021)
  15. #30
    175 Post(s)
    So this tap shuts off flow of coolant through the heater core entirely? Instead of letting it flow through, and just rely on the selection flap to keep heat of vents ?
