Page 949 of 1049 FirstFirst ... 449849899939947948949950951959999 ... LastLast
Results 9,481 to 9,490 of 10488
  1. #9481
    May 2016
    lower west victoria
    30 Post(s)
    welding in slippers. I'm too scared to ask what you used for eye protection. ;-)
  2. The Following User Says Thank You to 10G For This Useful Post:
    mudski (4th May 2020)
    461 Post(s)
    [QUOTE=Mickhead;802093]
    Mig welding in slippers burns! Just a warning for others. Lol.
    By the looks of that weld you were definately jumping around in agony
    Doesn't help that maybe some whiskey was had too.
    Mickhead (4th May 2020)
  6. #9483
    194 Post(s)
    Decided to cover up the front side of the cargo barrier and also make the head impact area a bit safer, I used 8mm ply and its mounted off the cargo barrier - turned out great.cargo barrier board.JPG
    It is hinged at the bottom with piano hinge, so easy enough to get to the gear mounted on the cargo barrier back side.
  7. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    10G (4th May 2020), mudski (6th May 2020)
  8. #9484
    May 2016
    lower west victoria
    30 Post(s)
    Drove the Trol out of the garage and back in. Most I've touched it in the last 7 days.
    Haven't bought fuel for 6 weeks.
  9. #9485
    I did the same on the weekend, it was great fun.
    Last bought fuel in February.
  10. #9486
    May 2016
    lower west victoria
    30 Post(s)
    Did you put the hubs in?
  11. The Following User Says Thank You to 10G For This Useful Post:
    mudnut (4th May 2020)
  12. #9487
    461 Post(s)
    Thats a great and neat idea Phil. Whats stopping the board from dropping down on a passengers head though?
  13. #9488
    194 Post(s)
    I have bolted it thru the cargo barrier in both top corners, 80mm x M8 with offstand nuts to get it vertical and hold in place. You can just see one of the bolts/nuts on the bottom left hand of the photo
  14. The Following User Says Thank You to PeeBee For This Useful Post:
  15. #9489
    194 Post(s)
    Wired the hydraulic winch back up after 11 months disconnected, ran it in and out twice, all good. Did the same for the rear electric winch, good to exercise them and get them warm. Think I may have isolated the squeaking noise - the bonnet release mechanism bolts were loose from a previous activity, now bonnet closes and squeak has disappeared - for now.
    Waiting on the replacement Couplertec unit to arrive - warranty return, and the big w2a pump is on its way from NSW to Vic.
  16. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (7th May 2020)
  17. #9490
    49 Post(s)
    Did my wheel rotation this afternoon and notice that the disk was wet, not alot but enough to my attention. Undid the brake caliper to get a better look. Is this a leaking axel seal? It's the rear right hand side if that makes a difference
    The last pic isn't wet, fair bit of guck tho.
  18. The Following User Says Thank You to jay see For This Useful Post:
    mudnut (17th May 2020)
