Page 1092 of 1450 FirstFirst ... 925929921042108210901091109210931094110211421192 ... LastLast
Results 10,911 to 10,920 of 14491
  1. #10911
    201 Post(s)
    Packing to go camping and realised someone has stolen two dog leads on the back of the GQ ute!!!
    Who the hell does that!
    Somebody in desperate need of two dog leads!
    Avo (20th January 2018)
    Errrrr.... woops. Lol
    Lol...didnt even notice....i liked the pic. ...and the fact ya cars on the road again
  5. The Following User Says Thank You to Avo For This Useful Post:
    Winnie (20th January 2018)
  6. #10913
    I'm not happy that the angry thread has almost as many posts as the happy thread.
    We should be happy not angry but I spose we can be happy the angry thread post count is behind the happy count unless we get angry over something trivial then the happy count will fall behind the angry count which might make happy members angry that the angry members aren't happy then the happymembers can't make angry members happy and get the happy count back in front of the angry count but... pffft... I'm happy to leave it altho it makes me angry when I don't finish a post on a happy note... sooo... I hope all you angry dudes are happy that you made a happy dude angry
  7. The Following 8 Users Say Thank You to the evil twin For This Useful Post:
    AB (20th January 2018), Avo (20th January 2018), Bidja (20th January 2018), Clunk (21st January 2018), Hodge (20th January 2018), mudnut (21st January 2018), NissanGQ4.2 (20th January 2018), TPC (21st January 2018)
  8. #10914
    i try not to post here,,,....but sometimes it's hard not to...i'm happy i didn't die...numerous times......
  9. The Following User Says Thank You to Avo For This Useful Post:
    MB TD42 (21st January 2018)
  10. #10915
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Someone needs a hug !
  11. #10916
    wowow thats really average hey
  12. #10917
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Ground Fault AGAIN THIS MORNING. Most likely Wallabies looking for moisture and chewing the wiring insulation of my PV (solar panels) wiring. Generated my own electriity (off-grid) and one of the Sunny Boy inverters (MPPT) is showing up a "ground fault" again this morning.
    Bugger, thought it was moisture ingress from running gravity feed supplied water sprinklers to cool/wet the general area down as so hot here yesterday 41DegC (a fire prevention measure). While I was running the multi-meter over sys, the good lady noticed chew marks (lovely wallabies) thru the outer insulation of the flexible link cable. Lucky for the wallabies though that they mainly come out and play at night as these arrays can happily run at nom 380 and 420 vols o/c (series and parallel strings-6.1kW).. More mods but rather doing others though. A pic of PVs, wonder if they would fit on the GU
  13. The Following 2 Users Say Thank You to Bidja For This Useful Post:
    jack (21st January 2018), MB (21st January 2018)
  14. #10918
    472 Post(s)
    G’day Bidja mate, wondering if a bit of untasty grease or the like on the wires might deter them for you? Not sure what reaction grease has on wires though mate!
  15. The Following User Says Thank You to MB For This Useful Post:
    Bidja (21st January 2018)
  16. #10919
    22 Post(s)
    Why don't you have mechanical protection around the cables
    96 GQ coil/Cab
    08 G6eT
  17. The Following 3 Users Say Thank You to Ben-e-boy For This Useful Post:
    Bidja (21st January 2018), Clunk (21st January 2018), Winnie (21st January 2018)
  18. #10920
    Jul 2017
    37 Post(s)
    The transmission lines are protected above ground except for the section that has been damaged. This section is a flexible link cable (1m length) that allow for free movement as the array frames track the sun (full east to west). Will replace cabling and run it through a length of thick walled flexible tubing and hook it up higher and hopefully out of easy reach.
