Results 11 to 20 of 36
Thread: TD42 T Gets real hot but only when towing
    Feb 2011
    Shed
    45 Post(s)
    G'day Velty welcome aboard mate. Excellent mod mate well done! Jump over to the intros mate so the other members can say g'day and let us in on any other trade secrets ay
    Patrol Guru Ade's Avatar
    Apr 2011
    Sabah, North Borneo
    Gday people,
    I kinda agreed with Velty.
    I cracked my old motor pre combustion chamber, all of them and now I had this turboed stock motor and ip for about a year or so with 15psi boost. I had no issues with overheating since with this motor no matter how hard I trashed it but not on a long pull up a steep grade and hills. I found that ect are very related to egt at least in my case. On a heavy load on that hill my egt will only max out to 680c pre turbo but with that egt my ect will be around 110c. Bringing down the egt to 540c will bring down the ect to 100c. All these while I am ok with it. But I wanted a worry free driving up that hill, without need to keep an eye on the gauges.
    Last week I started playing around with the ip max load screw. Instead of tweaking it up I had it down to about a quater turn from the stock setting. As expected less power but so did the egt and ect. Speeding up wot at that same hill my egt now will only max out to 480c and ect at 82c. How bad was the power lost..well it's an auto. 1st & 2nd gear will pull up close to 4000rpm no problem just slower. 2nd gear will pull up to 4000rpm and speed is about 90kmh. Continuing wot on 3rd gear will be a struggle to get it up pass the 3000rpm even on a flat road.. Maybe a good i/cooler set up will let me stayed with the stock ip setting.
    By the way, she's a pretty heavy trol with diy drawer slider bars winch etc, 315/75 with 4.6 diff. F/consumption was about 20l/100km. I cannot tell if she had over fuelling or what with the stock ip setting. There was no black smoke only a slight puff on a hard pull.
    I will stick around with this setting for a while a see how she goes on f/c and off road with that. If really needed, I will slap in a fmic and that head drilling mod.
    Ade
    btw, both motors are TD42 silvertop
  4. #13
    Apr 2011
    Sabah, North Borneo
    Theres another point, few weeks ago I got my hands working on my brother's trol wacking in a turbo to his silvertop. With his stock ip and same turbo spec as in mine, his trol power were so much less than mine with the stock ip. I had to turn his max load screw up to half a turn just to get the power as in mine with quater less turn on the max load screw. His trol were struggling to pass the 3000rpm on a 4th gear. He had no overheating issue with this set up so we will stick with it atm.
    So there you go..two so thought stock ip with different out come.
    Ade
  5. #14
    Mar 2017
    Has anyone tried one of the cooling system cleaning additives with this problem? Supposedly clean the rust and gunk out of the radiator and motor. I have done the following and still have an overheating issue when towing:
    Thermostat replaced, radiator cleaned and tested (twice), water pump replaced, fuel mix checked and adjusted by the guys who wound it up (also have a larger exhaust fitted by them), viscous fan hub and fan blades replaced, Silica added to the viscous fan hub. Then replaced the thermostat and radiator cap again with Nissan parts just to be sure (76.5 degree thermostat) and added a water temp gauge to check the temp rather than relying on the cluster gauges.
    Running out of options and looking for any words of wisdom!
  6. #15
    Jan 2018
    Hi. Fuel Mix,??? Leave it alone standard fuel pump. IT WILL NOT OVER HEAT. wazza.
  7. #16
    330 Post(s)
    Quote Originally Posted by MJP74 View Post
    You should install an Exhaust Temp Gauge (pyro) and a manual Boost controller and then have it dyno tuned professionally. You should avoid towing in 5th and avoid towing at 2000rpm. Better to change down and rev at 2500rpm. The TD hates 2000rpm.
  8. #17
    Jul 2016
    The only thing you have not replaced is the radiator. If some of the internal cores are blocked no matter what you flush it with won't unblock it. If you are really keen remove one tank off the radiator. With a lawnmower starter spring and garden hose carefully clean all tubes you be surprised at how much crap comes out.
  9. #18
    175 Post(s)
    Hey Darren mate. Are you saying this only when towing or in general? I cruise at 100km/h and it sits on 2000rpm, or just over in 5th. At that speed/rpm it has enough guts to cruise. But if i need more power to over take or something, I'd have to gear down to 4th. It just feels like its labouring.
    In 4th, its 2400rpm or there abouts. It just seems like its revving too much if im in 4th crusing at 100.
    581 Post(s)
    I would say only when towing mate for the load on the transmission at low rev's.
  11. The Following User Says Thank You to AB For This Useful Post:
    Hodge (17th January 2018)
  12. #20
    581 Post(s)
    Having saying this I try not to cruise or let the rpm go below 2000 regardless unless down hill of course.
  13. The Following User Says Thank You to AB For This Useful Post:
