27th September 2017, 09:36 PM
#7991
Ran and connected the wiring for the tank and filter heaters today. Marked out the position for the bonnet 'gills' to aid under bonnet cooling, and cut the bonnet supports away from the skin - doing the cut-outs tomorrow.
27th September 2017 09:36 PM
29th September 2017, 11:29 AM
#7992
PeeBee
Bonnet gills installed, fiddly job, heart in mouth as I cut the holes in the bonnet though! Came up well. The fibreglass gills didn't come with any fixing bolts, so used araldite, with mixed success - can't take a tensile load so had a few break off. Ended up using a black SIKAFLEX product and the bolts in combination to pull it down to the bonnet profile. DSC01832.JPGDSC01833.JPG
I will eventually get them colour matched when i get the rear section of the roof above the rear doors touched up from numerous dropping of stuff and chips formed.
The Following 2 Users Say Thank You to PeeBee For This Useful Post:
GQtdauto (29th September 2017), Rossco (29th September 2017)
29th September 2017, 11:51 AM
#7993
Smart like tractor
PeeBee
It would be interesting to see a string/tissue paper or whatever test to see which way the air flows through the vents
96 GQ coil/Cab
08 G6eT
29th September 2017, 12:09 PM
#7994
Good idea, will do that for sure. I am working on the air flowing out from under the bonnet.
29th September 2017, 02:10 PM
#7995
Patrol Goddess
Polished his bullbar.
KATROL- The 2nd
GU TD42TGi
Silent member 1208
The Following 6 Users Say Thank You to katwoman For This Useful Post:
mudnut (29th September 2017), mudski (8th October 2017), PeeBee (29th September 2017), Rossco (29th September 2017), Stropp (29th September 2017), Yeti's Beast (30th September 2017)
29th September 2017, 03:51 PM
#7996
Smart like tractor
PeeBee
It will at slow speed definitely. I have installed these on a turbo tb42 and you can see the heat rising through at basically a stand still, but at speed it is high pressure at the base of the windscreen, and forward of the cowl. What I would like to know at say 100kmh which way air is travelling.
96 GQ coil/Cab
08 G6eT
29th September 2017, 05:16 PM
#7997
Ben-e-boy
OK, took a piece of fine string and stuck it to the bonnet. Went for a spin and totally baffled.
0-15K/HR no movement
16- 100K/HR, the string pivots around and faces the direction of travel up to about 95, then it starts to flap from side to side - drivers to passenger side. The string sits flat on the bonnet. the location of the string was varied from centre of bonnet to in front of the new GILLS, and then on the GILLS, exactly the same effect.
At idle, I can feel a gentle airflow coming out of the GILLs, but not enough velocity to move the string.
So I have achieved what i wanted that being a low speed escape path for the heat, but now curious to understand the airflow which is contrary to what i would have thought - I was expecting a flow in the direction of the windscreen - doesn't happen.
Any ideas????
29th September 2017, 06:17 PM
#7998
If the only way airflow could escape from the engine is through the vents it would but I'm sure most of it if not all escapes through the bottom of the engine because it's the easiest path of travel for it .
29th September 2017, 06:54 PM
#7999
GQtdauto
Agree???????
29th September 2017, 09:07 PM
#8000
Smart like tractor
PeeBee
Any ideas????
I would redo that test using multiple pieces of string all over the bonnet, and around the vents, that way you will get a solid indication of is actually happening over the majority or all of the bonnet.
I really know bugger all on the subject, but the string flapping side to side, to me says turbulence and lots of it?
96 GQ coil/Cab
08 G6eT
PeeBee (30th September 2017)
