Results 21 to 30 of 31
Thread: 2003 GU Patrol 3L Losing Power
  1. #21
    SkippyGU JackCollo's Avatar
    Dec 2016
    Melbourne VIC for now
    Alright sounds pretty straight forward. What should I use to clean out intake manifold? All the carbon build up?
    Currently own a ZD30 2000 GU patrol with a dead injector pump about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
  2. The Following User Says Thank You to JackCollo For This Useful Post:
    lmath56 (22nd May 2017)
    Carbie cleaner should do the trick, make sure all components are dry
    before re-assembly
  5. The Following User Says Thank You to threedogs For This Useful Post:
  6. #23
    Mar 2017
    Smile
    Quote Originally Posted by lmath56 View Post
    Hi,
    I have a 2003 GU Patrol 3L Diesel,
    About a week ago when I was driving, I turned a corner and accelerated off,
    When I was in 4th or 5th gear and was at about 2500 RPM, it seemed to lose pulling power.
    I put the clutch in and revved it a bit and it seemed fine, I drove around for a while and all seemed good, but then it happened again.
    I didn't notice it again for about another week, when it happened while just accelerating up a road.
    I haven't noticed it since.
    On all cases I wasn't accelerating hard.
    My Patrol has a Dawes valve set to 15 PSI.
    The engine was reconditioned about a year and a half ago and had a new fuel pump installed.
    Does any one have any idea what could cause this?
    Thanks,
    Lucas
    The mechanic looked at the car today and found that the MAF was quite dusty, so he gave that a clean.
    The fuel filter had quite a bit of water in the separator so he replaced that.
    One of the hoses near the turbo was leaking a bit of oil. It was pushed back on and tightened,
    He took it for a drive and it seemed fine, and i did as well. It seems to start a bit faster and have slightly more power now.
    I will need to tow a trailer full of tiles and concrete in the coming days so that will really test whether this fixes the issue or not.
    I will update if there are any further issues,
    Thanks everyone for your help!!
    This is the first time I have used this forum, and I will definitely be back!
    Lucas
  7. #24
    Feb 2015
    Dartmoor, England
    Make sure you do Lucas...we'll want to know how you get on.
  8. The Following User Says Thank You to Daveyboyjunior For This Useful Post:
    lmath56 (24th May 2017)
  9. #25
    It didn't go up too fast, I didn't strain it.
    I got it to about 400 Max.
    Yes when it lost power it seemed to get a bit warmer than usual.
    I will definitely give the MAF a clean
    Sent from my ONE A2005 using Tapatalk
    Disconnect the battery when you clean the MAF
    will re-set the ECU, Check vacume hoses for cracks etc
    make sure they are in good nick
  10. The Following User Says Thank You to threedogs For This Useful Post:
  11. #26
    Also if you're going to be towing bricks and concrete tiles
    have a good look at strengthening the rear shock towers
    they will crack
  12. #27
    Dec 2016
    Glad to know we could help you Lucas please let us know how you go with everything after you test it and what not.
    Good luck
  13. #28
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Just to add another aspect to this conversation, last night it was a bit cool and I was in a 100kph area. As I accelerated I could see the guage go up to the 15psi then over to 16psi. If I continued at this it then went to limp. Normally my dawes is set to 15psi max and I only get 16psi in cold weather. This morning the max at 15psi is back to normal. So here is the theory. I think that the spring tension in the dawes changes just a smidge when it is cold and allows the setting to drift to over 16psi, which is where the limp mode kicks in. When the motor heats up or on a warm day the spring maintains its set point and all is good. Any other thoughts on this?
  14. The Following User Says Thank You to 4bye4 For This Useful Post:
    Daveyboyjunior (25th May 2017)
  15. #29
    Feb 2015
    Dartmoor, England
    Hi there,
    On your gauge, you may see a little bounce over your set limit.
    To make your Dawes a little more responsive some guys (me included) just pop the spring out and stretch it just very slightly, and this added tension within the chamber should help the Dawes stay on your chosen limit.
    Just my thoughts...
    We don't have big temp differences over here unless it's freak weather.
    Look at my post count... I've scored a century who hoo.
    Gonna thank you for that 4bye4!
  16. #30
    Aug 2014
    Kingsley WA
    15 Post(s)
    Quote Originally Posted by Daveyboyjunior View Post
    Hi there,
    Just my thoughts...
    Sorrite mate.
