10th May 2016, 05:32 AM
#61
Any pictures of the setup??
To me if your struggling while slow but fine on the highway then is a simple flow issue..
So do you still have the standard viscous fan plus 3 thermos??
10th May 2016 05:32 AM
10th May 2016, 06:06 AM
#62
Yes to fans
Landy 96 cant get photos on here
Enjoy The Journey
Dont Be In A Rush To Reach Youre Final Destination
10th May 2016, 06:35 AM
#63
landy96
Yes to fans
Your past 25 posts mate you should be right to upload some?
10th May 2016, 01:15 PM
#64
The fins and thickness can be critical.
Ok your is thicker but the "FPI" fines per inch, need to be less than standard to allow air flow through it.
EG--If FPI is large, ( more/same number fins per inch ,not less ) it is like a blanket being put over the rad, reducing airflow.
A properly matched,for the job thicker rad to fpi ratio build spec can take full advantage of the extra cooling capacity, mis-matched and problems.
I'm not saying this is the cause just something worth exploring.
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
18th May 2016, 08:56 PM
#65
Diesel Mechanic said head gasket or cracked head ??? Problem solved ..
Bloody subscribe scam popups on here keep jaming my phone .
I have popups blocked on my phone but it doesnt stop these
18th May 2016, 09:14 PM
#66
landy96
Using tapatalk or the forum?
Sent from my SM-G800Y using Tapatalk
19th May 2016, 03:13 AM
#67
landy96
Is it using water or oil?.
Whats the compression like?.
19th May 2016, 08:02 AM
#68
I just read through the whole thread trying to figure WTf are we talking about as the title is for a TD42 pump. Nothing to do with cooking it.....
I was asking myself the whole way through, have you and or anyone thought to check the radiator for oil or bubbles, Tried checking sump oil for water? The where signs all the way of a crack or leak as well plenty to say that the engine needed a good cooling system clean. The factory cooling on the ZD30's are pretty bloody good, thermos will never beat a engine driven clutch-fan.
19th May 2016, 08:58 AM
#69
LostBenji
Lots of info has been lost between the 2 threads..
19th May 2016, 10:44 AM
#70
I am he, fear me
"What once was lost must now be found"
The Following User Says Thank You to the evil twin For This Useful Post:
BigRAWesty (19th May 2016)
