19th July 2016, 07:46 AM
#21
I have one of the USA branded
Well know branded winch on my patrol
Retail is over $1500
What a waste of time and money
Never again
I will go with the cheaper models in future and save my money
19th July 2016 07:46 AM
19th July 2016, 09:42 AM
#22
Patrol Guru
Yeah No Dramas Kallen thanks again 👍🏼
The Following User Says Thank You to Sprock For This Useful Post:
BigRAWesty (21st July 2016)
21st September 2016, 10:29 PM
#23
I read a while ago (a number of years I think) that one batch of aldi winches were re-branded iron-man winches.
Depends who aldi get a good deal from.
Check it out on the net and some of the other forums have discussions on them.
22nd September 2016, 04:24 PM
#24
I ran two Aldi winches on two Prado's over ten years. Never had an issue with either one. If the Warn ever died on my Patrol I would not hesitate replacing it with an Aldi unit. I think the most important thing with the cheaper winches is to pull them apart when new, replace the grease with quality stuff, and apply a bead of sealant on all gaskets/seals.
22nd September 2016, 06:20 PM
#25
Theres a mob at the back of Tullamarine Park drive that see 12,00lb winches for about $400
Place is called Radum they import chinese equipment like pipe benders,, 12t press'sPlenty of gear
thats for sure
29th September 2016, 02:45 AM
#26
Dirtydog16
Check it out on the net and some if the other forums have discussions on them.
Yep, I've heard the same, might have been around 2010ish.
Sent from my XT1068 using Tapatalk
4th October 2016, 11:04 AM
#27
I have just purchased the domin8er just need to figure how to install on a factory bullbar.
8th October 2016, 01:02 AM
#28
Just wondering if anyone has the new domin8r x winch and if so can you rotate the gear box i read some where that you cant bit just thought id ask the question.
Cheers in advance
8th October 2016, 11:02 AM
#29
Andy76
Cheers in advance
Not sure how new the one you're talking about is, however I bought one over a year ago and you could rotate them. I did a write up on installing into a std Nissan winch bar. You'll also find a thread on installing into an alloy bar using a winch cradle if you have a search.
2007 GU ST-S 4.8 Patrol.
40mm heavy duty springs, Dual batteries,
140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
9th October 2016, 01:03 AM
#30
Only just had it delivered ill check out your post and take it from there.
