3rd August 2016, 02:40 PM
12V timer circuit
Hey Guys,
I'm looking for a timer circuit that cuts of the power after 10 seconds or so.
Whether it's a finished product or a hobby electronic type build circuit are both good for me.
I can build it from parts from Jcar, or ebay.
But, I prefer a finished unit so i can save some time.
Basically the delay circuit I'm after should turn the power on for ten seconds when the ignition
is turned on, then cut the power until I reset(turn off the ignition and turn on again).
So, obviously I'm looking for a 12V timer unit that controls 12V power with a timer.
I'm wondering whether the below circuit would do that.
http://www.ebay.com.au/itm/121209831...84.m1436.l2649
or any other suggestions, links, etc will be appreciated.
thanx
3rd August 2016 02:40 PM
3rd August 2016, 03:02 PM
I am he, fear me
Probably be fine but at $4 if it isn't then no biggee...
Sounds like your after a flip flop cct
More expensive option http://www.jaycar.com.au/timer-progr...e-12v/p/AA0378 any good?
The Following User Says Thank You to the evil twin For This Useful Post:
3rd August 2016, 05:18 PM
You could use a cheap turbo timer.
The Following User Says Thank You to bazzaboy For This Useful Post:
3rd August 2016, 08:53 PM
bazzaboy
What is a "turbo timer"? Where would I get hold of a one from?
Thanx
3rd August 2016, 08:55 PM
4th August 2016, 12:09 AM
I am he, fear me
'ere ya go Cobber https://en.wikipedia.org/wiki/Flip-flop_(electronics)
Most hobbt circuits will use a 555 timer and the flip flop switches a relay
4th August 2016, 12:53 AM
4th August 2016, 08:15 AM
#8
Back when Dick Smith sold real electronics the catalogue had a data section with schematics & all the info you needed to build the "one shot" that you want.
You will not be able to build anything for the price of your e-bay find, a piece of veroboard will cost you more. I once got some blank 555 boards from RS Components for a project, but they were way more that what you are looking at.
This kit from Altronics is pretty good, but $35 might be out of your price range and you have to build it.
http://www.altronics.com.au/p/k6140-...12v-timer-kit/
Graham
The Following User Says Thank You to GeeYou8 For This Useful Post:
4th August 2016, 08:52 AM
#9
dom14
Thanx
Sorry mate. Re-read your post. A Turbo timer will not go down to seconds, lowest setting is usually 1 minute. ( a turbo timer is a timing device to allow a turbo to run on and cool down )
4th August 2016, 11:01 AM
#10
I am he, fear me
bazzaboy
Spoil sport... I was about to tell Dom a "Turbo Timer" was a normal FactoryTimer with an aftermarket Turbo, Chip and Water to Air intercooler.
