19th December 2011, 04:18 PM
roofy
Ok guys had a look at the stuff you have put up
looks very impressive easy to read sooooooo what
would cost you to build these sets
I hope the long reply isnt him having a heart attack after working out the cost for us! !!
19th December 2011 04:18 PM
19th December 2011, 08:41 PM
roofy
With the Ozi $$ as good as it is, they’re not too expensive at all. Check out http://www.mo-co-so.com/
Depending on what system you wanted, you could get a car pc for well under $500 or spend up to $1200.
Monitors for around $250.
A good system could be had for under $1000
There is plenty of free software available. www.mp3car.com
The Following 2 Users Say Thank You to Chaz For This Useful Post:
Clunk (19th December 2011), rottodiver (19th December 2011)
19th December 2011, 09:28 PM
i just had a good look at the website.... i am going to be going with this PC for the car.... just need to do some comparisons etc but it looks like the way to go!!!
19th December 2011, 10:11 PM
as i said before looks way to flash for me. id be happy with one of those computers that sit on the dash please hahaha
which one could i get
19th December 2011, 11:28 PM
Honestly a cheap chinese 7 inch laptop will work fine for ECU talk and a few movies if you wanted to get away.
Something like this will be tops.
http://www.ebay.com.au/itm/NEW-7-Min...item3a6e21badd
Get the Windoes CE version
23rd December 2011, 07:23 PM
just go to a nissan outlet. the just hook the computer to your patrol and you can already see whats the problem of the car. usually if theres an ecu problem check engine sign doesnt show. the only way is to by a bran new ecu. repairs are not applicable
28th December 2011, 12:19 AM
#17
can i get a scangauge for my GU 01 3.0 tdi
29th December 2011, 08:51 PM
#18
Leighw85
Hey Leigh, Merry Christmas mate.
The Scangauge is only for OBD-II compliant cars, so won't work on your 01 patrol.
Your only option for a stand alone readout is the ECUTalk Consult LCD Display with the OBD-II plug. These units do work on ZD30 Patrols, but it seems that they are currently out of stock.
31st December 2011, 11:09 PM
#19
Yeah merry Christmas to you to mate, all be a little late hope you have a great new year also.
So these ecu talk ones just plug straight in somewhere?
31st December 2011, 11:28 PM
#20
Rotaredom
Leighw85
yeh mate In the GQ's they are up around the drivers side kick panel, not sure in the GU's but could be around the same place. I'm sure I seen a thread on here somewhere that showed the location of the GU's plug. Ill have a look 2morrow for you if you can't find it.
all the best for the new year
Todd
