Results 1 to 9 of 9
Thread: Zd 30 using a cup of water a day ?
    Dec 2017
    Hi guy’s an girls
    I have a GU 2000 model that is using about a cup of water a day running around town , have had pressure test done an radiator test done . an come back all clear , have resently replaced inter cooler an installed a catch can witch is filling up with water after running around for a week approximately 500 mm water , no water in oil . Any ideas what could be the problem?
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Looks like a blown head gasket or a cracked head.
    Do bubbles appear in your plastic header tank?
    Never heard of water in a catch can before.
    Get a TK test done. It will tell you if exhaust gasses are getting into the water.
  4. The Following 2 Users Say Thank You to BillsGU For This Useful Post:
    Pipa (12th December 2017), the evil twin (11th December 2017)
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Yes sounds a bit weird. I guess if water was getting from the jacket into the sump it could boil off and get distilled in the catch can. Strange one though.
  6. The Following 2 Users Say Thank You to 4bye4 For This Useful Post:
  7. #4
    Agree with above posts ^^^^ not a 'common' issue and also not a desirable one.
    I don't think the water is getting to the sump and distilling tho, the 'free' water would be under the oil and to make a cup a day and not emulsify in the oil when running would be really weird.
    Obviously somehow the water must be getting into the breather if it is lost from the coolant and found in the Catch can.
    That sorta sounds like a cracked head from water jacket to atmosphere to me
  8. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    4bye4 (11th December 2017), Pipa (12th December 2017)
  9. #5
    Aug 2014
    Kingsley WA
    15 Post(s)
    Interesting. If that is the case you will have no indication with a compression test or testing the water for hydrocarbons.
  10. The Following User Says Thank You to 4bye4 For This Useful Post:
  11. #6
    Quote Originally Posted by 4bye4 View Post
    Yeah, hope the OP keeps us in the loop as too what the outcomes of this problem turn out to be... will be the first ZD to have water contaminated MAF instead of oil...
  12. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    4bye4 (11th December 2017), AB (11th December 2017), Pipa (12th December 2017)
  13. #7
    80 Post(s)
    Not a water-cooled turbo is it?
  14. #8
    Dec 2017
    No bubbles, no water in the oil eather? Turbo is water cooled and can’t find any leaks also EGR has a water line , if water was leaking from EGR valve it would avaparate in to exhaust ?
  15. #9
    80 Post(s)
    Since you have pressure tested the system, and no leak was found, I think there is a crack or warp in the turbo, which is opening up when hot, letting water into the into the intake. Looking at catch can diagrams, I could be wrong though.
    Years ago, our Fairmont was using water and we pressure tested the system multiple times. It was left for ages pressurised, but no leak was detected.
    It turned out that the water cooling jacket under the carby was warping when hot, allowing water to spray into the inlet manifold.
  16. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    AB (12th December 2017), the evil twin (12th December 2017)
