2nd October 2017, 07:11 PM
Very ordinary Brakes?
Hey guys thanks for your help in advance. I have a 1993 TB42E auto 4.6diffs with 35s patrol wagon with twin piston front callipers, the problem I have is holding the brake pedal down hard stationary in low range 1st gear just above idle it drives off brakes won’t hold it, going rock crawling down a hill at idle I have to keep knocking it into neutral they just won’t hold. Braking on road normal driving isn’t too bad considering tyre size etc. I have rebuilt all the callipers machines rotors and new softer compound pads and replaced the vacuum lines adding a small tank inline for vaccum reserve. Really annoying me any suggestions would be appreciated.
2nd October 2017 07:11 PM
2nd October 2017, 07:24 PM
If you've rebuilt the brakes have you replaced the brake lines to the calipers with an inferior line that's expanding under pressure ? Have heard of this happening once .
My 94 is pretty much stock as far as brakes go and with 33s on I was able to pull up from about 90 to a dead stop when a car decided to do a u turn unexpectedly in fairly short order .
2nd October 2017, 07:50 PM
Thanks I’ll replace them over the next week and see if it helps. 👍
2nd October 2017, 09:49 PM
I upgraded my nissan rubber hoses all round to the teflon/ss braid ones and made a massive difference. Then later changed the pads to the softer ones - better again. I only have single piston calipers also.
2nd October 2017, 10:09 PM
Yeah steel braided hoses make a big difference.
2nd October 2017, 11:29 PM
What did you pay for the Teflon lines and where from? Did you do the long diff to chassis and short calliper to diff?
2nd October 2017, 11:51 PM
I contacted Safebrake, one of the vendor sponsors on the forum. It's been a while but they supplied all hoses to swap over so possibly 6 in total. No idea of the cost, but the service was great and swift delivery. Had a workshop swap them over and again from memory it cost 2 hrs labour plus brake fluid. PM Safebrake and get a quote.
I have a 3" lift and they handled that with ease.
7th October 2017, 05:11 PM
I’ve got my hands on a GU booster and master going to give that a go before the ss line I’ll let you know if it’s any better.
7th October 2017, 07:10 PM
Lucas Bree
From memory it was around the $400 mark for all hoses. Four wheels and the two chassis to diff hoses. No point in just doing some of them. Marks Adaptors I got them from I think. Twas a while ago.
7th October 2017, 07:43 PM
So, just by upgrading to these Teflon braids , it will improve braking ?
Brakes are done my next service . Pads , fluid and thinking of getting these upgrades.
Sent from S6 using TapaPro v.3.73
