31st October 2018, 03:09 PM
#1061
Flywheel either rattle gun or breaker bar. Just need to wedge a screwdriver or prybar into one of the flywheel teeth and lock it against a dowel i think from memory. Kindof a fun job when you've only got two hands lol. . .
Winnie (31st October 2018)
31st October 2018 03:09 PM
31st October 2018, 03:14 PM
#1062
Administrator
Lol yep I forgot about that yeah that spot is correct for feed, sorry bro!
31st October 2018, 03:19 PM
#1063
The 747
Rossco
Yeah problem there is because the engine is just sitting on a tyre it wants to turn onto its side. Would probably help if I could get somebody to hold onto it.
31st October 2018, 05:41 PM
#1064
Daily Lurker
Winnie
Cheers Nicco! Hey with the sticker you print can you only do vinyl or can you use other materials?
not sure, what do you want to cut and ill let you know if i can cut it lol
31st October 2018, 05:43 PM
#1065
Daily Lurker
Winnie
I think the only option is going to be an effing big rattle gun. Mine won't budge them and with a big breaker bar it just want to rotate the engine onto its side because it is not secured.
i have a rattle gun that supposedly can produce 2000NM of torque, your welcome to borrow it mate?
31st October 2018, 06:27 PM
#1066
The 747
rusty_nail
Something to withstand engine bay temps. I wanna get a new sticker printed for the rocker cover like this one.
rusty_nail
Holy shit lol, mine is apparently good for 380nm but it won't come close
31st October 2018, 07:13 PM
#1067
Daily Lurker
Winnie
ill ask at the local supplier if they do high temp stuff. may be better cutting the reverse logo(as in the borders of the letters) then you spray painting high temp paint onto it?
i can send down the rattle gun if you like?
actually ask AB if hell pick it up on the way to sprocks bucks, are you going to that? if you can sort it out you can borrow it then, then return it when it works?
31st October 2018, 07:50 PM
#1068
The 747
Thanks mate for the offer, MB has one as well and is already travelling through so we will give his a go!
31st October 2018, 08:25 PM
#1069
Moderator
I have something that might get it done tio winnie, ill bring it down mate.
Check out my Toy -->
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
MB (31st October 2018), Winnie (31st October 2018)
31st October 2018, 08:34 PM
#1070
The 747
Cheers Daz!
This is where I am at now. Not a lot more to go.
I need to grind the crank hole out on my sandwich plate to fit the larger crank of the turbo motor.
Need to install fuel pump and the lines and injectors.
Flywheel and clutch
Vac pump when it shows up.
I need a couple of adaptors for turbo oil feed and a new drain hose.
Will need to get an oil feed hose made for the vac pump
I am going to relocate the vac canister to the drivers side.
5mm spacer to be made for the tacho sensor
The Following 3 Users Say Thank You to Winnie For This Useful Post:
AB (31st October 2018), Avo (1st November 2018), MB (31st October 2018)
