Page 752 of 1049 FirstFirst ... 252652702742750751752753754762802852 ... LastLast
Results 7,511 to 7,520 of 10488
  1. #7511
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Had the on John Deere tractor hydraulics but no idea of working pressure , very similar to the old reusable fittings on oxy / acetylene hoses , the barb part screws inside the hose and the outer screws over the outside sort of crushing and biting as it goes .
    They only failed at the join if allowed to swing freely for to long , used to tie up the slack with hay bale twine .
    194 Post(s)
    Ok, I will have a look at them, but if I can get the details of the hose fittings currently in use, I can get the hoses made up and fit myself. I like the idea of the crimp fitting, even though these hoses will remain static in location and not be exposed to any movement fatigue. I did have a look on google and recall seeing these fittings in use. Thanks for the input, appreciate it.
    Phil
  4. #7513
    Dec 2016
    Northeast Victoria
    41 Post(s)
    These are the type of fittings I was talking about .
    http://www.ebay.com/bhp/reusable-hydraulic-fittings
  5. The Following User Says Thank You to GQtdauto For This Useful Post:
    juzzs8 (17th April 2017)
  6. #7514
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Oops , one disappeared so put another up and now have two , someone please delete one .
  7. #7515
    Quote Originally Posted by PBBIZ2 View Post
    Have you got a link to these? I am assuming they don't need crimping?
    http://www.mhfgc.com.au/index.php/pr...egory=14524205
    Field service attachables/ reusables.
  8. The Following User Says Thank You to nissannewby For This Useful Post:
  9. #7516
    Phil
    If you send me pics and measurements I might be able to help you out.
  10. The Following User Says Thank You to nissannewby For This Useful Post:
    threedogs (16th April 2017)
  11. #7517
    194 Post(s)
    Thanks for that. I have to work tomorrow and have one of the contractors who does machining at a hydraulic company in Melb. I will see if he can identify them first then sort out which way to go. Now its so close am itching to get it sorted and put to bed.
  12. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    GQtdauto (16th April 2017), threedogs (16th April 2017)
  13. #7518
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Played with the solar regulator , the settings are adjustable and it turns out the setting for charge was 13.7 volts for some reason , why do I always throw the manufacturers recommendations away before reading them .
  14. #7519
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Started on the wiring for the trans oil gauge , all hooked up bar the sensor wire and the sensor , I will buy another banjo bolt and have it drilled and tapped for the sensor and then swap them over .
    While I had the fuse box out and the shrouds of the steering wheel column I'm going to run left and right blinkers to the new mirrors so I'm going to run the wires now into the front doors .
  15. The Following 2 Users Say Thank You to GQtdauto For This Useful Post:
    MB (20th April 2017), threedogs (19th April 2017)
  16. #7520
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Blinker wires done , trans oil gauge mounted and all wires except sensor are hooked up .
    Spent hours trying to get the wires through the rubber conduit in the doors and ended up cracking the shits and have run them alongside the conduit and using small cable ties fixed the wire to the conduit .
  17. The Following User Says Thank You to GQtdauto For This Useful Post:
