18th July 2016, 07:29 PM
Removing A/C evaporator from GQ Patrol
Hi all,
Has anyone Removed the A/C evaporator from a GQ Patrol, and have any helpful hints.
The first thing I would like to know is if the dash needs to be removed or not.
Thanks for any help.
Mark
Reason: spelling
18th July 2016 07:29 PM
19th July 2016, 02:32 PM
Why do you need to remove the evaporator?
20th July 2016, 03:35 AM
Hi,
Need to replace
Last time I had a/c problem I checked in the box and the fins were half corroded away.
Don't no why, 1 owner nothing sprayed in there and was clean inside (no leaves)
So now needs a gas so I suspect its corroded though a tube now.
20th July 2016, 10:15 AM
Gq evaporator is about as easy as it gets
1. Get the system degassed if any in it
2. Remove lines from firewall side
3. Remove glove box
4. Remove wiring connectors to case
5. Remove the 10mm bolts mounting the case
6. Remove whole evaporator case (slides back then down then back) but you will see what i mean when you do it
The Following User Says Thank You to johno90 For This Useful Post:
22nd August 2016, 09:13 PM
johno90
3. Remove glove box
Isn't that just the blower fan case ?
"Can't" is a dirty 4 letter word.
Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
Sip on the "t", and consider what you've got left to work with
22nd August 2016, 09:23 PM
Umm nope. Fan case is the case to the left with the motor sticking out the bottom. Evap case is in the middle and is very easy to get out once you know how. Even on a gu there is no need to remove dash to do evap or heater cores. If you want next time i do one ill take some pics and make a how to.
The Following 2 Users Say Thank You to johno90 For This Useful Post:
Arfa Brayne (23rd August 2016), mudnut (22nd August 2016)
22nd August 2016, 09:31 PM
johno90
That would be a an excellent idea.
22nd August 2016, 09:32 PM
#8
Will do in a few weeks gotta replace the evap on the old mans gq when i get back to Brisbane
