Results 21 to 30 of 39
Thread: Shortie shortening :)
    May 2016
    lower west victoria
    30 Post(s)
    Great thread looking forward to more updates.
    2 questions.
    Looking at the diff, does it rain salt water in Wales? And 20 minutes of sheep action, um I hope that means something different in Wales than it does down here (or in NZ) ;-).
  2. The Following User Says Thank You to 10G For This Useful Post:
    MudRunnerTD (19th July 2020)
    2 questions.
    I think the roads are salted to deal with black I've aren't they?
  5. The Following User Says Thank You to rusty_nail For This Useful Post:
    10G (15th July 2020)
  6. #23
    May 2016
    lower west victoria
    30 Post(s)
    Yeah you gotta be right, that thing was seriously rusted.
  7. #24
    192 Post(s)
    Quote Originally Posted by makeitfit View Post
    Motor plans are a bit sketchy at the mo but I have a mechanical pump, soon to go off to DieselMeken I also have a very large supercharger !!!
    Initially I'll be quite happy with the 200 bhp straight out the box.
    Ooh nice, sure it will be awesome. Seen many of his vids, he's the rock star of injector pumps over your way. .
  8. #25
    Expert makeitfit's Avatar
    Aug 2011
    Aberporth beach, west Wales, UK
    Things are starting to move again, which is awkward when I'll have no axles in the morning
    Decided I better make some kind of chassis dolley trolley thing to keep it moveable. 50mm box and a tape measure to the rescue
    We had a few odd wheels about so kind of worked around them .
    Keeping it simple , I thought simply measure the body mount positions and support the chassis with this frame. How hard can it be
    The boy's got a new welder, so I'm not allowed anywhere near it , lol, shame
    That's the wheel plates on, now turn it over and weld on the nut caps.
    Spin it over again and bolt the wheels on, oh, wait, bugger, that's on wrong
    Never mind, a quick cut, grind and reweld the plates on the right way round
    Better
    Then the rather awkward task of wrapping the chassis over the dolley
    Got there in the end though, as I dropped a bollock on my sums the rear needed a quick cut n shut again, oops.
    So tomorrow these axles are off on a pallet to Malta , as you do . Then I get to start bracing my Y61 axles
    Onwards.
    Y60 Patrol 4.2 d SWB in puke green
    2" body lift, 2" pedders suspension lift, 35" Simex muds on excel 16" alloys, needs a turbo :/
  9. The Following 5 Users Say Thank You to makeitfit For This Useful Post:
    0-TJ-0 (18th July 2020), 10G (18th July 2020), Cremulator (18th July 2020), mudnut (18th July 2020), Rossco (18th July 2020)
  10. #26
    Aug 2011
    RAINING, again
    Wet, wet, wet, not the band but my pants, euw but hey the axles are off
    Found a suitable pallet and got the heavy load sorted ready for it's trip to Malta, gotta love tinterweb ££££
    Got the trolley dolley back inside for a dry out
    The frame has a cock up due to my measure error, so decided to fix it by making it more versatile lol
    Got some 60mm box to slide over the 50mm box. Welded on some nuts so now I can vary the width of the frame for some reason that will become clear in some future project, maybe
    End result is signed off by the top dog
    Anyway, it's been one of those ideas to make life easier. I thought a couple of hours lol, nope, but hey it's here now and once I've done chassising, it'll work a treat under the shell
    Onwards
  11. The Following User Says Thank You to makeitfit For This Useful Post:
    10G (19th July 2020)
  12. #27
    Sik build mate!!!
    The use of the D Pillar is very nice mate. And that tail gate is Awesome!!!!!
    What the bloody hell is Sheep Action???
  13. #28
    Aug 2011
    Sik build mate!!!
    https://gfycat.com/filthyillinformedfrogmouth
  14. The Following User Says Thank You to makeitfit For This Useful Post:
  15. #29
    Aug 2011
    Sunday and the sun is out , yay. Typical as I'm on paint today
    So my super chassis trolley has another trick. I can tip it up either end and get underneath easily. Just as well cause I'm cutting out the coil towers ready for rewelding them further aft.
    Took some datum point measurements as reference.
    You can see a lot of surface pitting but probably won't reuse these bits anyway.
    Spring tops and drop link points removed and area cleaned up.
    Now a lightweight chassis
    Steering box was next to go, damn that thing's heavy. Made the whole trolley experience even better though
    At last , I got some paint on. I'm using BUZZWELD rust encapsulator primer . It's almost as expensive as printer ink, so it better bloody work
    It may not look much different but it's safe to go back in the rain at least.
    I've ordered diff case protection as they I think are worth buying. I'll make the rest of the bracing.
    Trailing arm material is proving more difficult to find but I'll get it .
    Onwards.
  16. The Following 2 Users Say Thank You to makeitfit For This Useful Post:
    10G (20th July 2020), mudnut (20th July 2020)
  17. #30
    Aug 2011
    Diff lock actuator thingy
    I have a snag regarding the diff lock actuator thingy. Mine is goosed
    I'm also fitting diff case protection as below. Do you guys know of any alternative gizmos that will do the job ? Especially one I can incorporate into this casing ?
    Thanks in anticipation
  18. The Following 3 Users Say Thank You to makeitfit For This Useful Post:
    10G (20th July 2020), Rossco (20th July 2020), rusty_nail (20th July 2020)
