Results 1 to 10 of 12
Thread: Rear spring tower repair
    Patrol Guru paulyg's Avatar
    Ballarat
    Can anyone recommend someone in the Ballarat area that can weld on the Atoc rear spring tower reinforcing kit?
    2010 TB4.8, 5 speed auto TI Wagon, Beaudesert ceramic coated Extractors and 2 1/2 inch exhaust, 3inch lift, BP-51 shocks, Black hawk radius arms and drop boxes, Road Runner Offroad billet alloy draglink, Boss air bags, 295/70/17 KM3s, Redarc Gauges, GME XRS UHF, Autometre fuel gauge, Alpine head unit with offroad maps, Carbon winch, Opposite lock bull bar, Light Force Strikers, Safari Snorkel, Duel long range tanks, work in progress.
    Reidy's in Bendigo or 4WD Obsession in Melton
    Ballarat
    Thanks MudRunner
    175 Post(s)
    Do these weld on units need the body to be lifted ?
    109 Post(s)
    No Hodge, I have the ATOC kit installed by them and no body lift.
  7. The Following User Says Thank You to Plasnart For This Useful Post:
    Hodge (9th July 2016)
    175 Post(s)
    Was yours a bolt on or weld on ?
    My 3L was done there as well bolt.on kit but I thought the full weld on proper tower braces needed the body to be lifted.
    109 Post(s)
    I actually cant remember 100% but thought it was weld on. Ill have a bit of a look later.
  10. #8
    Ballarat
    The Atoc weld in kit, which is what I want to use, does not need the body to be lifted.
    I would have used one of the bolt on kits, and install them myself, but my spring towers have started to crack, so there is going to be some welding any way.
  11. The Following User Says Thank You to paulyg For This Useful Post:
  12. #9
    Ballarat
    I ended up getting the weld on tower braces done at Edge Automotive in Howit street Ballarat, after a 4000km trip through outback NSW an SA, with the Patrol loaded up and towing a camper, no further problems, so I can recommend them for the job.
  13. The Following User Says Thank You to paulyg For This Useful Post:
    MudRunnerTD (3rd September 2016)
  14. #10
    Quote Originally Posted by paulyg View Post
    Cheers for the feed back. How much was it drive in drive out?
