Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Troubleshooting Diff Lock Issues
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Guys, I remember there was a couple of threads about post 2012 patrols with rear diff lock not engaging
    I can not find any at all
    Any one remember the issue or can help me search?
    Its holding up my current sale unfortunatelly. Its booked into Nissan on the 18th but i would
    like to resolve the issue before then.
    Basicaly, when i turn the rear diff lock on the light flashes and wont go solid to say its engaged
    ...........on the road
    ________________________
    ______ 2017 D-Max _______
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Only thing I could find is the following .
    My understanding of the e-locker is that it dose use the original ring gear and pinion gear. So if the factory diff lock has different specs to the LSD, which the e-locker has been adapted for it won't fit. As there is an e-locker for the front and a different one for the rear, they don't have one for the factory diff lock which makes sence. That could be a reason for it being incompadable. As for your factory locker, when I got my patrol I found that the diff lock wouldn't work. I was given advice just to tap the diff housing with a hammer to free things up a bit. I must say I gave it a bit more than a tap but it has been working perfectly ever since and I actuate it a least once a month just to keep things freed up.
  4. The Following User Says Thank You to GQtdauto For This Useful Post:
    Maxhead (10th April 2017)
    ACT
    I'll give that a shot tomorrow. Cheers
    From memory I remember some connector being loose as well so I'll check all that too
    ................on the road
  6. The Following User Says Thank You to Maxhead For This Useful Post:
    GQtdauto (10th April 2017)
  7. #4
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    It's normally the vacuum solenoid mounted on the passenger side firewall that fails. It's worth while checking the wire that runs down to the rear diff, make sure it hasn't been damaged or cut in two.
    The problem with mine was it had stripped the teeth off the diff lock assembly inside the diff.
  8. The Following User Says Thank You to Yendor For This Useful Post:
  9. #5
    ACT
    Thanks Rod, I'll have a look. Any chance of a pic mate?? Please best buddy...lol
    Was it a big job in your case? Mine is still under warranty so I could be lucky but as you know Nissan is a bunch of pricks..lol
  10. #6
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    What do you want a picture of? the vacuum solenoid?. I don't have the remains of the rear locker apart from some loose teeth. I've heard some people were able to get warranty and some people weren't able to get warranty with the stripped teeth. I just went for an E-Locker replacement.
    The first thing I would check if was I was you would be the electrical wire and vacuum hoses that run down to the rear diff. Then check the vacuum solenoid operation.
  11. The Following User Says Thank You to Yendor For This Useful Post:
  12. #7
    ACT
    Yeah I was after the vac solonoid pic but I'm pretty sure I found it.
    I was actually thinking it was an electronic locker from day one till I saw all the air lines
    Thanks Rod, ITs ganna go either way
  13. #8
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    I can get of photo of it if you like. Just let me know if you need it. It's mounted to the firewall just below the LHS bonnet hinge.
  14. The Following User Says Thank You to Yendor For This Useful Post:
  15. #9
    ACT
    The vac solanoid looks ing good shape, like new really
    This is the bit I'm worried about as it's a bit out of shape
  16. #10
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    It’s a bit hard to tell by the photo, what’s a bit out of shape? The whole unit where it mounts to the diff or the connection of the bottom vacuum hose.
    The bottom vacuum hose is for diff lock off. The top vacuum hose in your picture is diff lock on.
