24th May 2019, 10:06 PM
24th May 2019 10:06 PM
24th May 2019, 10:09 PM
Whoops, took me too long to type that crap, time to watch and get educated!
The Following 2 Users Say Thank You to MB For This Useful Post:
MudRunnerTD (24th May 2019), Rossco (25th May 2019)
24th May 2019, 10:54 PM
Great video actually mate, exciting new stuff to come!
Maybe just a few honest questions still though they didn’t quite cover or I nuffy missed no doubt.
Rope wear, big blokes words:
"It is proven not to be the case.....so far"
Skinny bloke, if the line drops out:
"rope on rope" (good safety still linked I guess)
They both agree together a soft shackles eye is the most common failure point yet pulley application has eye/knot rubbing against the pulleys side.
Honestly not trying to be negative, just can’t get my head around rope abrasion long term, please help?
24th May 2019, 11:36 PM
Moderator
MB
All good mate. The weakest link in the soft shackle is the eye around the knot. Regardless of its use that never changes. Considering this, how you set up the soft shackle when under load is important. Rather than trying to pull the back off the knot you fit it so the knot is near the load and trying to pull through. Much less load here.
So dyneema is very very slick mate. With the ring spinning slowly around the soft shackle there will be very little friction. They discuss it a little in the vid. A winch recovery through a snatch block or ring is half speed of winch. So slow.
Assuming your soft shackle is clean and the ring is clean then there is no dirt to cause damage. Your winch rope is not slipping through, it is rotating. No friction .
If under an extraordinary event the ring failed and the rope came out from over it it would be caught by the shackle, it is looped through the shackle. This is a bonus.
Check out my Toy -->
Rogue Dung Beetle
24th May 2019, 11:48 PM
MudRunnerTD (25th May 2019)
25th May 2019, 06:29 AM
OK, so the ring stays static and the winch rope slips around the ring, yes, clever, tried to watch the video but kept getting smashed with pop ups, so gave up. Reckon I will stick with the snatch block for now as have not had one come apart in 30 yrs, but don't play in the same pit as others do.
25th May 2019, 07:15 AM
#17
Moderator
PeeBee
Hmmm i dont get pop up adds watching thar phil, only once at the start?
But no, the ring rotates just like a conventional snatch block. Instead of the bearing spinning the ring spins around the centre soft shackle.
Rogue Dung Beetle
25th May 2019, 07:19 AM
#18
Moderator
You can see here how it would spin as a dry bearing. If it did not spin then absolutely the original concern would be true, the dirty winch rope would slip around and act like a saw blade and slice it in half.
Rogue Dung Beetle
25th May 2019, 07:23 AM
#19
Moderator
But in operation see how the knot of the soft shackle is positioned. Not trying to pull the head off the knot backwards.
Rogue Dung Beetle
25th May 2019, 07:28 AM
#20
Moderator
The weakest part of the soft shackle is the loop because it is the thinnest. It is the size of the single rope, in this case 12mm dyneema. (Strong), what makes it weakest is the diameter of the bend around the rest of the rope, (at that point its 2x 12mm rope). By positioning it in this way the knot takes a fair bit of that stress.
Rogue Dung Beetle
