Page 930 of 1049 FirstFirst ... 4308308809209289299309319329409801030 ... LastLast
Results 9,291 to 9,300 of 10488
  1. #9291
    194 Post(s)
    Made the mount bracket for the Quicktifier unit, hooked it up, no sparks or flames, idle voltage went up 0.3V, so good result. Starting on the rear wiring mess tomorrow, or Monday, still have to sort out a couple of items now without power since my clean-up, and finalise the wiring looms under into corrugated protection. Mounted the wiper washer bottle after first extending the piddly wiring looms to the little pumps - added 300mm to each cable so they can be connected whilst the washer bottle is out of position instead of having to grow spider fingers to plug them in - worthwhile mod. I believe.Then onto the lighting set-up to deliver the 28V to all the LED's as previous.
  2. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (4th January 2020)
    472 Post(s)
    Best modification on Mrs MB’s old stocky wagon to date hopefully!
    If we treat the coin mechanism operation like a swear jar and between the four of us we should have all credit cards paid off in no time at all ready for 2021 rear locker adventures out there to come too
  5. The Following 9 Users Say Thank You to MB For This Useful Post:
    Bidja (6th January 2020), BSRT.Beast (4th January 2020), Cremulator (5th January 2020), jay see (4th January 2020), mudnut (6th January 2020), mudski (5th January 2020), PeeBee (4th January 2020), Plasnart (5th January 2020), Rossco (5th January 2020)
  6. #9293
    461 Post(s)
    Thought I’d check the aux batteries water level prior to our trip. Although, it’s been working fine and running a fridge and light with ease I thought best check anyway. Just as well I did. It took a far bit of water...
    This was full. So maybe a litre and a half went in! Wow!
    Now running my CTek smart charger on it and it passes the charge hold test. Lucky!
  7. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (6th January 2020), Rossco (5th January 2020)
  8. #9294
    192 Post(s)
    Bloody love it, your a thinking man I tells ya . . .
  9. The Following User Says Thank You to Rossco For This Useful Post:
  10. #9295
    109 Post(s)
    Freaking crackup clown you are mate!
  11. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
  12. #9296
    194 Post(s)
    I reckon you dodged a bullet there Mark.
    mudski (6th January 2020)
  14. #9297
    461 Post(s)
    Yeah I reckon... it now has a full charge and holds the charge and it held load too from my load tester. Phew!
  15. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (6th January 2020), PeeBee (6th January 2020)
  16. #9298
    194 Post(s)
    Yeah, expensive day in the shed. Hooked up the CTEK system to the new 300 amp alternator - didn't go well is perhaps the understatement of the new year. One the look out for an alternate system now. All hooked up correctly, just could not take the current. Snap crackle and pop then all the smoke started escaping and joined the bushfire smoke.dead smartpass.JPGfried board.JPG
  17. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    MB (6th January 2020), MB TD42 (12th January 2020), mudnut (7th January 2020)
  18. #9299
    May 2016
    lower west victoria
    30 Post(s)
    That should buff out mate.
  19. The Following 2 Users Say Thank You to 10G For This Useful Post:
  20. #9300
    461 Post(s)
    Ask Ctek for warranty. surely good enough for a laugh at least.
  21. The Following User Says Thank You to mudski For This Useful Post:
