Results 1 to 6 of 6
Thread: ZD30 diesel reserve tank won't shut off when empty.
    Jan 2020
    SA
    My diesel reserve tank won't shut off when empty. Car is a 2003 ZD30 Patrol. Reserve tank keeps trying to pump diesel even though empty. Any thoughts. Steve.
    Is your Sub tank fuel qty Gauge accurate?
    Jan 2020
    SA
    Hi,yes I check it when I fill it up that it takes 30 litres
    Quote Originally Posted by Steve SA View Post
    Hmmm, interesting
    The sub tank poota monitors the sub tank qty and should switch off the pump when it thinks the tank is empty
    If the gauge is working OK then I would assume the sender and wiring is OK and suspect the "Sub Tank Control Unit".
    But before any of that have you added any extra earth straps from the chassis to the body etc?
    Patrols are notorious for earthing gremlins esp the Sub Tank System and an "extra" earth strap from the vicinity of the sub tank pump to the body will often get rid of weird faults maybe 75% of the time
  6. The Following User Says Thank You to the evil twin For This Useful Post:
    mudski (30th January 2020)
    Jan 2020
    SA
    Hmmm, interesting
    Thanks for that I'll try an earth strap and see if it helps. Steve.
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    can't you just turn it off manually?
    2008 CRD Auto Wagon
