9th January 2017, 05:51 PM
9th January 2017 05:51 PM
9th January 2017, 07:34 PM
Moderator
I believe the Pedders kit is what is used by Telstra for their wagons. @GUwesty has the pedder kit.
The only time you can really do the GVM upgrade is pre-delivery prior to first rego. There is a thread on the forum in the vendors section somewhere that lists the kits specifically.
Check out my Toy -->
Rogue Dung Beetle
9th January 2017, 07:44 PM
Moderator
I'm on my iPhone so I'm a little restricted but here is a thread with a couple of other threads linked.
http://www.nissanpatrol.com.au/forum...hlight=upgrade
Rogue Dung Beetle
9th January 2017, 07:46 PM
Adventurist
MudRunnerTD
There are quite a few shops over here that offer the kits and used to do up to 3500kg post rego, but as mentioned that has all changed in WA from December 2016 due to the authorities chucking a spaz about most of them exceeding the axle limits. So most only offer 3300kg kits now and Pedders is the only one I could find who have done the necessary engineering and do the required diff housing and coil tower mods to achieve 3505kg. I've pulled the trigger on it now and getting the Pedders GVM Upgrade done. I guess time will tell if it performs ok.
9th January 2017, 07:49 PM
Adventurist
MudRunnerTD
Yep, I'd read most of the threads on here and elsewhere. A lot of it seems to be relevant to the utes only and I can only find a few references to late model GU Wagons. But thanks for the links, I am all sorted now, just getting a bit of info up there for anyone else searching in the Perth area.
9th January 2017, 07:56 PM
Adventurist
Just had a call from Pedders. The GVM Upgrade can only be applied to the 5 seaters, so they need to remove the 3rd row and belts. Doesn't worry me as I will have drawers fitted anyway, but may be relevant to anyone intending on upgrading a 7 seater.
9th January 2017, 09:16 PM
Patrol Guru
Having had pedders suspension gear on my Ute when I bought it I have left it there but would I go and buy myself? No.
I have found they have used Neoprene bushes in the Panhard and I am suspecting that other components will also have the same. Just my $0.02
9th January 2017, 11:05 PM
#8
Adventurist
gubigfish
Cheers, I am kind of stuck between a rock and a hard place if I want the 3505kg though, so I'll risk it and see it how their gear goes. I've heard of a few with no complaints on the Pedders and some have been running it for years. Anyway the deal is struck, so I'm committed now.
10th January 2017, 01:37 PM
#9
Adventurist
Just to note on this thread for anyone searching. I've also elected to go with Castor correction bushes (Rubber) and an adjustable draglink. These are not absolutely necessary for the small lift, but recommended. This brings the total cost of this GVM Upgrade/Lift to $4464.00 done and dusted.
10th January 2017, 05:21 PM
#10
Hey steve.
Mine went threw state wide 4x4 in vic but is taken to 3495.
Something to do with axle loading and tyre ratings etc..
But yes, my towers are braced with the superior kit, axle is laminated and lovels custom kit used..
But..
Youll want it loaded all the time if going an off the shelf kit..
Ours is around 2.9-3T daily and by geese it was like driving a brick...
To the point of nearly dangerous on our crappy roads down here..
I had it drifting across the lane on a corner at 110 due to the bumps..
So i now have a different setup.
Gone standard springs and air bags.. The kevlar bags are rated for 500kg.
If we go on a solo trip ill drop the heavier springs in again..
Ive heard $4000 is the cost from statewide..
I guess they dont have much compitition so charge what they like..
Sent from my SM-G800Y using Tapatalk
