Page 109 of 116 FirstFirst ... 95999107108109110111 ... LastLast
Results 1,081 to 1,090 of 1157
Thread: Winnies 747 TD42 GQ
  1. #1081
    581 Post(s)
    Yeah I've got the o rings, I'm gonna install the pump and have both vac pumps running into the canister on the drivers side.
    Gonna be very easy to run a vac hose from the timing case mounted pump there, and there are already solid vac hoses going across the firewall so I will just go from the alternator to one of those solid hoses and from the other end of that to the canister.
    Darren reckons he also had a good improvement just from moving the canister over.
    Ok cool! It's a hard line across the firewall so vac distance shouldn't make a difference or very minimal but either way mate go for it!
    Just make sure you utilise double vac though mate.
    I actually have a second canister on the shelf at home and could run double canisters lol. Could even seperate the clutch from the brakes and have them on their own pumps.
  4. #1083
    581 Post(s)
    Winnies 747 TD42 GQ
    Yep I've always wanted to experiment with larger canisters/storage etc...
  5. #1084
    49 Post(s)
    Flywheel either rattle gun or breaker bar. Just need to wedge a screwdriver or prybar into one of the flywheel teeth and lock it against a dowel i think from memory. Kindof a fun job when you've only got two hands lol. . .
    This is how I've done it in the past.
    Yeah problem there is because the engine is just sitting on a tyre it wants to turn onto its side. Would probably help if I could get somebody to hold onto it.
    Rest the engine on his side....
    Or, you should be able to wedge something between the teeth and the ground. That's only if Nickos monster doesn't work.
    Seems to be coming together nicely.
  6. The Following User Says Thank You to jay see For This Useful Post:
    Rossco (1st November 2018)
  7. #1085
    330 Post(s)
    Yeah i have removed the hard double fuel line and the vac line off the fire wall. Pointless plumbing. Moving the canister to the drivers side made my clutch so light i didnt think i had one!!! Cant believe the xhamge.
  8. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Hodge (1st November 2018), Winnie (1st November 2018)
  9. #1086
    581 Post(s)
    Awesome!
    Are you running double vac though?
  10. #1087
    Awesome!
    Only the kool kids run double vac haha.
    I got the vac pump and flywheel today. Need to get the flywheel machined up and a hose made for the vac pump.
  11. The Following User Says Thank You to Winnie For This Useful Post:
    AB (1st November 2018)
  12. #1088
    192 Post(s)
    Yeah was thinking that, can join the double vac wanker club now lol.
    You want me to drop in at home or work tomozz, should be coming through mid morning.
  13. #1089
    330 Post(s)
    Wankers indeed. Nah single vac pump. I think the improvement us a co sequence of the canister volume is very close the the booster and isnt reatricted by 4m of 8mm tube
  14. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    growler2058 (1st November 2018)
  15. #1090
    581 Post(s)
    Yeah ok, it's just Winnie is still using his Alt vac too so he still has to run that to the firewall with rubber hose and across the firewall hard pipes to rubber hose junction along with a custom pipe from T engine to the new cannister location which no doubt he'll use rubber hose too so yes huge improvement with double Vac but very long lengths of rubber hose that's all.
    This is all minor though so all good. That's why for Winne's double Vac set up he should leave it all as is IMHO, block off T vac pump for now until he finds OEM line but all good, both will work fine.
