Page 285 of 565 FirstFirst ... 185235275283284285286287295335385 ... LastLast
Results 2,841 to 2,850 of 5645
  1. #2841
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    what size panel I have a spare 80 watt here I may do similar with lol ??
    I have a 160w foldable mounted on rhino roof racks and removable.
    Now would you run this to your AUX battery or have it switchable so the start can get some love as well
    @sooty_10
  4. #2843
    Aug 2014
    Perth
    10 Post(s)
    if your gonna go a 4" snorkel I wouldn't try and fit the factory one before hand, the holes needed probably won't quite line up with your 4" one and then you'll have extra holes to patch in your guard.
  5. #2844
    Up under the front deflector is that too far away from the battery for you ???
    If you need to weather proof it whip done to Safeways and grab a tupperware
    dish to suit.
    I wouldn't put it on the roof anywhere, MPPT should as close to the Aux Battery as practicable
  6. #2845
    Bendigo
    7 Post(s)
    Quote Originally Posted by gubigfish View Post
    That's exactly my hesitation until I decide which way i'm going.
  7. #2846
    Bendigo
    7 Post(s)
    @sooty_10
    I currently have a piranha dbs which has no interconnect or dual sense. Also contemplating down the track upgrading to the redarc sbi212d dual sense one. Currently looking at hooking only through aux.
  8. #2847
    Bendigo
    7 Post(s)
    Yeah not going roof mount for it. Either under bonnet/behind dash or in rear on cargo barrier.
  9. #2848
    Quote Originally Posted by sooty_10 View Post
    Yeah I was led to believe the closer to the battery the better, how about in
    the foot well on the left hand kick panel. Its only a short run to the Aux battery from there.
  10. #2849
    Bendigo
    7 Post(s)
    Yeah one of my contemplated options. I might even add a fusebox / junction in behind there somewhere.
  11. #2850
    Some high pressure braided hose arrived , I also have some quick connect fittings to suit.
    This will join some air tanks I have on the cargo barrier, hopefully This will help it look neat.
    http://www.ebay.com.au/itm/291816824...%3AMEBIDX%3AIT
    http://www.ebay.com.au/itm/251948189...%3AMEBIDX%3AIT
