Page 284 of 565 FirstFirst ... 184234274282283284285286294334384 ... LastLast
Results 2,831 to 2,840 of 5645
  1. #2831
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    Finally bite the bullet and am going to setup a solar reg permanent in the truck. Also got the Bluetooth dongle module so I can get live info on my phone and 30 day history too.
  2. The Following 2 Users Say Thank You to sooty_10 For This Useful Post:
    jay see (14th July 2016), Touses (15th July 2016)
    I use them a fair bit (not the Dongle tho)
    One minor issue (but major design fail) IMHO is the LV disconnect jumper is proud of the case so is easy to bust off/dislodge.
    To get the best result if you have multiple panels is hook them up in series not parallel.
    MPPT is more efficient at the higher Input volts.
  5. #2833
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Quote Originally Posted by sooty_10 View Post
    Nice ice been thinking about doing the same. Though where to mount it and also where to mount the panel itself
    Lucus30's 1999 GU ST TB45E
  6. #2834
    462 Post(s)
    A new Panasonic PVR to replace the HTPC.
  7. #2835
    Bendigo
    7 Post(s)
    The bluetooth plugs in where the jumper would go. The settings etc are then controlled through a phone app. Yet to try it but thats my take on it. So no jumper needed.
  8. #2836
    Bendigo
    7 Post(s)
    Quote Originally Posted by lucus30 View Post
    I've got my solar on the roof already. Just need to get the time and motivation to find a suitable spot for the regulator.
  9. #2837
    Didnt buy it but scored a 42" single row light bar with spot in the centre and flood on the outside.
    My son found it while doing traffic duties, Ill never use it as I like my double row spot bar.
    But you never know, still trying to talk myself into removing my driving lights and replacing
    with a 600mm light bar. decisions decisions lol
  10. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    BigRAWesty (16th July 2016), sooty_10 (16th July 2016)
  11. #2838
    Up under the front deflector is that too far away from the battery for you ???
    If you need to weather proof it whip done to Safeways and grab a tupperware
    dish to suit.
  12. #2839
    Bendigo
    7 Post(s)
    dish to suit.
    For convenience I was even thinking on the cargo barrier. It would mean at least a couple of meters run (still less than the 10m cable it came with) but access would be simple and straight forward as I already have 6 B&S twin core running to a junction down back and was contemplating running power to roof rack for lights from there too. Although running power from snorkle side out of bonnet would be neat (also have junction there). No snorkle yet though. Got a factory one in the shed from old gu ute. But contemplating 4" snorkle so not sure i can be bothered installing factory nissan haha. First world problems.
  13. #2840
    what size panel I have a spare 80 watt here I may do similar with lol ??
