Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
Thread: Belt Tensioner Assembly (CRD)
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    I've bought that one..
    Bearing is an nks bearing which imo should be good..
    But the bushes are shoit.
    I'm serious looking at making some..
    Maybe even a tensioner change over setup.. you give me your shagged one and I'll give you a rebuilt one with quality parts..
    Sounds like a plan what about this bearing ntn wc-87503 ive used it a few times in a rebuild
    if the body is ok bolt holes not worn little shocker ok for $30 for the bearing go for it
    at the moment I'm running a $50 jobbie of e bay seems ok so far time will tell
    you can also get the pully from auto barn $70 not sure about the price but you can get them
    plus a torx tool
  2. The Following User Says Thank You to Sir Roofy For This Useful Post:
    BigRAWesty (19th May 2016)
    43 Post(s)
    Quote Originally Posted by roofy View Post
    plus a torx tool
    Yep I can get that bearing.. and was going to rebuild my factory one..
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Sir Roofy (19th May 2016)
  6. #23
    .......... TPC's Avatar
    63 Post(s)
    Does anybody know what torque the pivot bolt should be tightened to?
  7. #24
    TRAFALGAR VIC
    35 Post(s)
    I just do it up till tight but if your fussy its 68-77 nm
    tensioner retaining bolt 25-28
  8. The Following User Says Thank You to Sir Roofy For This Useful Post:
    TPC (19th May 2016)
  9. #25
    43 Post(s)
    The above linked part number is $155.54 from dubai. I wonder how much shipping would be.
    Is that genuine from Dubai?
    http://www.ebay.com.au/itm/111995440...%3AMEBIDX%3AIT
    This was the replacement bearing I was told of.
  11. #27
    174 Post(s)
    Description says single row ball bearing & pic shows double row roller bearing?????
  12. #28
    Expert Softy's Avatar
    May 2011
    Radelaide
    5 Post(s)
    Same here i do it by feel... Apparently if over tightened it can stop it from pivoting but i have never had an issue.
    2003 GU SIII Auto Grenade. All the goodies.
  13. #29
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by Softy View Post
    No issue here either easy job but one you don't need on a trip
  14. #30
    TRAFALGAR VIC
    35 Post(s)
    Took his glasses of and miss printed it
