Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 75
Thread: TD42 turbo types. Whats what?
  1. #41
    Sounds good. Once you get an idea from jpc of the turbo they want to use or what they recommend we can ho a bit further into the pump. A 12mm will most likely be the best option anyway.
    As for cost you have a non compensated pump so whether it gets built to an 11 or a 12 there should be no difference in price. But as i said earlier a 12mm really isnt working that hard to produce 160-170rwkw ( a well built one anyway)
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    mudski (21st June 2015)
    sunshinecoast
    so mudski , just exactly what have you got to start with . I gather you've got a motor , but what has it got on it , eg; injector pump and such , are you planning to rebuild / recondition the whole motor . is the motor in working order , how many k's on it . if the injector pump is in good working order it might be better to keep it for now and put the money saved into 4in" snorkel and larger airbox !
  5. #43
    So guys another question. If I want to do a Turbo upgrade can I kill two birds with one stone?
    1. Can I take the MTQ Turbo off the GQ and will it fit onto the GU without much fuss? Will this be an upgrade?
    2. What would be a good Turbo to fit into the GQ for a good power upgrade and plenty of room to pump up later without making other real changes to the manifold etc.
    Is this logic reasonable?
  6. #44
    465 Post(s)
    Quote Originally Posted by nipagu7 View Post
    A dead motor is what I have to start with. Needs injector pump, will be sorted after we sort out what turbo is chosen. Needs an intercooler. Will be sticking with top mount. Motor is going to be totally rebuilt. New OEM TD42Ti head. Basically starting from scratch. Its only just started and trying to figure out what parts I'm missing and what parts I need to get is doing my head in already. Someone did say to me a while ago if I were to do this I will be bald and in a straight jacket by the time its done.
  7. #45
    465 Post(s)
    FYI Darren. I am using stock intake and exhaust (or MTQ style) manifold. I suppose it all depends on what pump you have mate.
    But I'll leave this up to the guru's.
  8. #46
    1. Can I take the MTQ Turbo off the GQ and will it fit onto the GU without much fuss? Will this be an upgrade? No. The turbo in your gu is good for around 150rwhp. If its only the the turbo that comes with the dts kit from mtq then just sell it to fund the turbo on the gq.
    2. What would be a good Turbo to fit into the GQ for a good power upgrade and plenty of room to pump up later without making other real changes to the manifold etc.what sort of power are you after? Budget? Most will bolt to your manifold anyway.
    Logic is reasonable. Just need some more info. Also what do you want from the gu?
  9. The Following User Says Thank You to nissannewby For This Useful Post:
    MudRunnerTD (22nd June 2015)
  10. #47
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    All this effort and you could buy my gu Iv td42ti and put on all your good bits and sell the leftovers
    Such is the rule of honour.
  11. #48
    The GU is the tourer mate, it tows the camper and a little more power would be awesome. I don't need it to be a Kenworth though and don't want to spend a sh1t load on it. I want t upgrade the turbo and 125 to 130kw would be nice.
    With the GQ rolling on 37s and the Play car it makes more sense to go for something with potential fitted up to that.
    The GU has the 11mm pump and honeatly won't spend money net on the pump until it sh1ts itself. The Pump work on the GQ is more likely in a couple of years and would go to a 12mm pump if and when it needs a rebuild.
  12. #49
    If the pump on the gu is in good condition you could get anywhere up to 140rwkw. If your towing and a pump upgrade isnt on the cards I really think something like the UFI 16g Large will most likely be the best option. Also a gtx2863 like winnie would also be a reasonable option but isn't quite as easy as just bolting on like the ufi item.
    The GQ is probably open to a few more options. UFI 18 or 20 g and the garrett 3067 or 3071. All of those can support 200rwkw but the latter of the 2 (20g and 3071) have the potential to support more. Again the ufi items are practically a bolt on turbo. Where as the garrett will need a housing from the states to get the turbo working where you want it.
  13. The Following User Says Thank You to nissannewby For This Useful Post:
    MudRunnerTD (21st June 2015)
  14. #50
    I don't know the specs on the MTQ turbo on the GQ now, if you know what the standard MatQ Turbo is what would I expect from that turbo fitted to the gu and 11mm pump?
