Page 775 of 1049 FirstFirst ... 275675725765773774775776777785825875 ... LastLast
Results 7,741 to 7,750 of 10488
  1. #7741
    43 Post(s)
    Finally fitted the new rack. @TPC 2m on the dot from floor to top of rack
  2. The Following User Says Thank You to BigRAWesty For This Useful Post:
    MB (13th June 2017)
    Nov 2010
    Getting a life...
    38 Post(s)
    What do you think of it Kat?
    Haven't really driven it yet to notice. Much nicer than the sand blasted one tho.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  5. #7743
    461 Post(s)
    Drove my Patrol through some lovely country side and got to get a view like this.
    I did pretty well. I had a rather loud and concerning crack coming from the front rh hub when I engaged 4wd. So I did the entire weekends tracks in 2wd and on AT's. I was quite surprised how it went.
  6. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (13th June 2017), Rossco (13th June 2017)
  7. #7744
    461 Post(s)
    Washed it for the first time in five months! Neglect or what?
  8. #7745
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    I connected the emergency start function on my smart solenoid and installed a reverse camera so I can see my new camper when I'm backing up to it.
  9. #7746
    461 Post(s)
    Quote Originally Posted by Yeti's Beast View Post
    Yeah a reverse camera making hooking up to the camper so much easier hey. I have three lines on the screen when in reverse. Green, yellow then red, red being the closest to the car, this line i have right on top of the two ball/ hitch.I actually want to install a second camera higher up on the rear of the roof rack, and have a remote switch for this camera so I can look at the trailer to see how things are going whilst towing.
  10. The Following User Says Thank You to mudski For This Useful Post:
    Yeti's Beast (14th June 2017)
  11. #7747
    Expert johno90's Avatar
    Moranbah QLD
    Drove it haha! First time in months since starting to play with it, could not be any more happier boost response is just stupid 20psi by 1600rpm. My little experiment has worked well, my intake air temps under full load are 23 degrees!! with the water temp going into the water air cooler at 10 degrees. After I put some kms on it in the next week ill post up real world results and some piccies on what ive actually done to achieve it.
  12. The Following User Says Thank You to johno90 For This Useful Post:
    Touses (21st June 2017)
  13. #7748
    Jul 2015
    Camden NSW
    6 Post(s)
    Stuck my 40amp smart charger on the batteries to keep them in good condition. I've been doing this once a month for some time now, as the Patrol is no longer my daily drive.
  14. #7749
    Apr 2017
    I made a cheap aluminium heat shield for my aftermarket cruise control actuator. It is mounted on the firewall high on LHS, so gets a fair bit of heat from the turbo and exhaust manifold. The instructions said mount away from heat, so I thought the shield might be worthwhile.
  15. #7750
    Jul 2015
    Camden NSW
    6 Post(s)
    Fitted one of these. There are a number of good right-ups on them on Y-tube but got no responses from members on various forums I frequent. 30 day money back if your not happy with it, so I'll give it a go.
  16. The Following User Says Thank You to bazzaboy For This Useful Post:
    sooty_10 (27th June 2017)
