Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: Non-Patrol extendable towing mirrors
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Has anyone adapted the Chevy, GMC, F-truck style extendable towing mirrors onto a GU?
    I see the Clearview mirrors here are ~$740 and I can buy the American style units for sub $200USD. It doesn't look like they'd be difficult to adapt.
    I'll be in the US in August to see my grandkids so wanted to do some useful shopping while I'm there.
    John
    I found that site as well , first thoughts were we get ripped a new one
    Maybe they have a Universal style that would fit?
    What about the Nissan Titan??
    Do you still have the link??
    http://www.ebay.com.au/itm/CLIP-ON-T...YAAOSwBLlVAhl3
    Morayfield, QLD
    Your link is to clip-on mirrors. I don't want those, I want to fit the extendable mirrors that slide in and out. They're electric, heated and can have indicators in them as well. I want to leave them on and just extend them when towing.
    I don't want the hassle of fitting clip on stuff.
    John
    Oct 2010
    Old Bar, NSW
    Would it be worth taking a mirror off and tracing out a template also marking mount holes to take with you to the US?
    Macca
    Morayfield, QLD
    I thought I'd just take pics and measurements of the GU triangle and get what appears to be the closest
    If I'm going to make my own adaptor plate I'll probably have grind the new one a bit anyway.
    The important part will probably be the angle at which it leans in or out because they're not a precise vertical fit.
    John
  7. The Following User Says Thank You to jff45 For This Useful Post:
    macca (22nd June 2016)
    ... or use the Grey Nomad 2 step method of changing lanes.
    Step 1 - Turn on indicator (optional)
    Step 2 - Change lanes (under no circumstances check mirrors to see the resulting carnage)
    Seriously tho, John, if you do find something either very close or very easily adapted make sure you post up here (or start your own import business)
    Clearviews are great... but the price?... bloody hell!
  9. The Following User Says Thank You to the evil twin For This Useful Post:
    jff45 (22nd June 2016)
  10. #7
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    I usually try to avoid using the indicators both in the Patrol or my work truck. I find it encourages those behind to drop a cog and speed up beside you to prevent you changing lanes.
  11. The Following User Says Thank You to 4bye4 For This Useful Post:
    NissanGQ4.2 (25th June 2016)
  12. #8
    http://www.ebay.com.au/itm/L-R-Manua...oAAOSwhOBXUIJa
    boy they like their Tahoe and Dodge Rams ,GMC over there eh
    Ive fired off a few emails as well .see what results that brings
  13. #9
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    I LOVE my Clear Views - but they are pricey. Also they do stick out a fair bit even when retracted. I sent them a suggestion once to put a second hinge point close to the mirror. That way you could fold the arm back and then the mirror out and it would only stick out as far as the original mirror. I never received an answer from them.
    Also, I have had a problem with the driver's side mirror folding in when a truck went past. I informed them of this and they said the mirror had to be returned to them and for a price they would fix it. I told them I was on the road at the time and could not be without a mirror. To cut a long story short they eventually sent me the fix which was putting more tension on the spring by padding it out with a couple of washers. Go figure - they wanted it returned to do that?
    But I still love them.
  14. #10
    I saw these on a car a few years ago and grab some pics. This would be Sooooo easy to make!!
