23rd November 2016, 09:03 AM
#21
Tip12345
Mine is A 2005 td inter-cooled .. I have been looking for a Description of the injection system . It has one injector with A wire on it ! the Tacho is intermittent thanks to all
With your vehicle start by swapping the ECU relay. It's located above the fusebox inside the vehicle. You will need to remove the plastic trim above the pedals to see it.
The ECU relay is the top relay. Just swap it for now with the middle relay (interior fan).
Also check and clean the main ECU earths. They are connected to the engine inlet manifold about half way down the engine on the RHS.
Tip12345 (23rd November 2016)
23rd November 2016 09:03 AM
18th December 2016, 10:49 AM
#22
The very top one in the middle . ? Have been mucking around and now have a light for the aux tank on and switch for the aux tank does not work . It's driving me mad.
18th December 2016, 12:46 PM
#23
Tip12345
The ECU relay is the top relay. If your vehicle is a wagon it will more then likely be on the LHS.
The middle relay is for the interior fan. Just swap these two relays over.
Disconnect your batteries for half an hour should reset the sub tank module.
18th December 2016, 03:26 PM
#24
Tip12345
Have you inspected the wiring for any rubbing or breakages?
18th December 2016, 05:26 PM
#25
Yes have had a look but wires look good . It is a very tidy Ute has not been touched very clean and tidy that's why I bought it. Stock as a rock
18th December 2016, 05:38 PM
#26
I have only really seen these play up when the wiring has been damaged. The rpm sensor is a 3 wire sensor with shielding so if has rubbed anywhere interference can play its part. Or someone has put some pressure on the ecu plug possibly running extra wires through the cab. I would be trying yendors suggestion first though.
18th December 2016, 06:20 PM
#27
Thanks where is the sensor located . When I know I can have another look. This Ute is new to me still finding my way around it ..
19th December 2016, 09:20 AM
#28
Tip12345
well is is improving but .... This morning without the plastic around the fuse box. I noticed a ticking like a relay opening and shutting. it stopped and the Tacho started working .
Not sure which relay it was .
5th January 2017, 12:38 PM
#29
well its still not 100 % when the tacho does not work it does not run properly . It has a three wire sensor . Is there a way to test the sensor . I have been looking for a description of how the system works but cant find anything useful ....
hope every one has had a bit of a break .. back at work here flat out .
