3rd September 2016, 08:54 PM
#1491
Administrator
Above level mate but thanks for asking any questions mate as i am losing my ship with reasons.
No one way valve just hose mate but my next step is getting the correct oil drain fitting although supplied the incorrect one to begin with.
I have gone too far and may be chasing my tail but we saw oil coming out of turbo with no oil drain at all, just into container whilst engine running but could've been oil residue sitting in turbo already from past tests which is frustrating.
Here is a clear tube pipe installed test and its flowing.
http://youtu.be/LUwiSzxdV84
Oil from turbo...I'm solo here so video is crap
http://youtu.be/bEXliAD9Juc
3rd September 2016 08:54 PM
3rd September 2016, 09:10 PM
#1492
Administrator
Fwiw in the drain video. This is a clear tube, once oil hits the wall of clear tube it stays.
At the bottom is the oil hitting the barb so small amounts will come back "coating" the clear tube. That is not full of oil sitting at bottom, nor is top part either as you are seeing oil "splashing" "swirling" from the turbo.
However, oil drain fitting from turbo incorrectly supplied replacement is close to my last resort to be honest.
In fact, if that fails I have no idea what to do next?
3rd September 2016, 09:30 PM
#1493
Administrator
sooty_10
Does your oil return above or below the sump oil level? Do you have a one way valve in the drain line? Does it even need one I dunno. But could it be back flow up your oil drain? Sent from my SM-G925I using Tapatalk
Also, no you don't need a one way valve. You just want oil to flow the quickest way possible with as much volume you can give mate.
The Following User Says Thank You to AB For This Useful Post:
sooty_10 (4th September 2016)
3rd September 2016, 10:16 PM
#1494
Patrol Guru
Jesus Christ mate ! I hoped after our conversation the other day that you'd have got some direction from the turbo guru but obviously it continues 😩
The Following User Says Thank You to Sprock For This Useful Post:
3rd September 2016, 10:32 PM
#1495
Administrator
Sprock
Checked out fine mate which in my position was very disappointing lol
3rd September 2016, 11:56 PM
#1496
Smart like tractor
So what was the compressed air test outcome
96 GQ coil/Cab
08 G6eT
4th September 2016, 08:12 AM
#1497
Administrator
Ben-e-boy
Perfect, as per the video...
4th September 2016, 08:43 AM
#1498
That really sucks mate. Mine hasnt been driven since that trip either so I feel your pain
The Following User Says Thank You to JonnoD For This Useful Post:
5th September 2016, 06:54 PM
#1499
Patrol Guru
AB
That sucks big hairy balls mate
5th September 2016, 08:10 PM
#1500
Administrator
Sprock
All good mate, i may have an answer soon when I get back to Vic!
