Page 44 of 46 FirstFirst ... 344243444546 LastLast
Results 431 to 440 of 452
Thread: WA Meet - 10th & 11th of September
  1. #431
    Quote Originally Posted by Doggy View Post
    If they are the Staun tyre deflators then I have a set you can have for a reasonable price mate, lets discuss next meet up....................remind me though as the memory is has turned to shit
    Yep Stauns maybe slower (but then again probanly no slower that having to go round and deflate each tyre one by one) and a pain in the arse to initially set up, but once done, stick em on and let them do their work......
  2. The Following 3 Users Say Thank You to Clunk For This Useful Post:
    Bigcol (15th September 2016), Kimbo63 (16th September 2016), timbar (15th September 2016)
    109 Post(s)
    I dont use mine any more. Found the springs stuck so deflation pressures were inconsistent. Then sometimes i want 18psi and other times 25psi so had 2 set at 18 and 2 set at 25 and it took ages to deflate using only two of them. The Currie deflator, while more work, at least achieves consistent pressures and whatever pressure you want.
  5. #433
    Sep 2011
    adelaide
    18 Post(s)
    G`day Guys
    I use the end off an old hand pump or foot pump ( the one with the lever that folds down and pushes on the valve) these hold the valve open and it takes very little time to drop pressures.
    I must say that I was the last to leave the camp at the meet up and did a walk around and the place was spick and span,(didn`t even find any chunder)Well done guys and gals.
  6. The Following 7 Users Say Thank You to pearcey For This Useful Post:
    AB (16th September 2016), Avo (19th September 2016), Clunk (15th September 2016), Kimbo63 (16th September 2016), Stropp (16th September 2016), TPC (15th September 2016), Woof (16th September 2016)
  7. #434
    .......... TPC's Avatar
    63 Post(s)
    That is the reason I never got them, I always decide what pressure I will drop too at the time. I usually go 30 for long dirt tracks and sand can be anywhere between 25 and 10 depending on the conditions.
  8. #435
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    On a sad note though...
    The dumped cars, asbestos, tyres and crap on that track was disappointing gents!
    Is there fear of that track getting closed down over there, is there talks about that, is there pressure from other groups to close it down due to the ship dumped everywhere?
    It's always on the cards here unfortunately, SWAT 4x4 and several other crews were there the weekend before in a combined clean up
    Never underestimate the power of the tap, let it flow through you.
    www.swat4x4.com
  9. The Following 6 Users Say Thank You to oncedisturbed For This Useful Post:
    AB (16th September 2016), Clunk (16th September 2016), Kimbo63 (16th September 2016), MB (16th September 2016), Stropp (16th September 2016), Woof (16th September 2016)
  10. #436
    Quote Originally Posted by oncedisturbed View Post
    Yep trackcare WA is doing alot of cleanups in areas that are favourites of our 4wd communties..next one is down here at the yeagerup beach track and beach on the 26th sept...i'm in on that one...
  11. The Following 3 Users Say Thank You to Avo For This Useful Post:
    Clunk (16th September 2016), MB (16th September 2016), Sir Roofy (16th September 2016)
  12. #437
    found this on the way home...i think the town is Brookton...
  13. The Following 7 Users Say Thank You to Avo For This Useful Post:
    AB (16th September 2016), Bigcol (17th September 2016), Clunk (17th September 2016), firm351 (17th September 2016), MB (16th September 2016), pearcey (16th September 2016), Woof (17th September 2016)
  14. #438
    Patrol Guru firm351's Avatar
    Jun 2013
    Mundijong, WA
    4 Post(s)
    Thats pretty cool hey. Its in beverley not brookton.
  15. #439
    Ah fuck...knew its started with a --'b
  16. #440
    And now you know why they didn't let me find the campsite
  17. The Following 2 Users Say Thank You to Avo For This Useful Post:
    Bigcol (17th September 2016), Woof (17th September 2016)
