8th July 2018, 10:45 AM
#91
I gave the entire winch a bath yesterday evening. The brake assembly came apart fairly easily after soaking in the bath for a few days. my only concern in the facing of the brake assembly. Its pitted quite bad where the bearings runs. Think I'm up for new plates. Outside of it clean up pretty good though...
Thinking of putting a drum brace kit on it too while I'm at it.
8th July 2018 10:45 AM
8th July 2018, 10:47 AM
#92
The 747
Came up clean mate, that wearing inside is odd though! Haven't seen that before and not sure what to think about it.
8th July 2018, 10:58 AM
#93
Winnie
Bearings running dry and had a hammering. Wonder if I could get the facing welded up then machined back or something. I definitely cant use it how it is.
8th July 2018, 11:19 AM
#94
The 747
They are supposed to run dry though.
8th July 2018, 03:11 PM
#95
Winnie
Oh ok. Just had a hammering then.
Sent from my crapPhone using Tapatalk
9th July 2018, 12:14 AM
#96
Moderator
Yeah that bearing wear is disappointing. Replace the plates mate.
Check out my Toy -->
Rogue Dung Beetle
9th July 2018, 12:15 AM
#97
Moderator
Yes put a brace kit on it for sure.
Rogue Dung Beetle
9th July 2018, 07:15 AM
#98
The price for two plates is not far off a GP brake assembly. When the funds allow for more parts I need to do something about this.
9th July 2018, 08:50 AM
#99
Moderator
mudski
Chase a second hand one mate. someone with a box of bitss might have a spare they will sell you for $50. you only need the one that is worn which i assume is the outer one?
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
mudski (9th July 2018), Rossco (9th July 2018)
9th July 2018, 09:49 AM
#100
Failing that, I think a machinist could face up that surface and you might lose 0.5mm at a guess by the photo? If it was a piece of gear in industry, thats what I would be doing. The brake should not be affected as it has to cope with friction pad wear anyway, food for thought.
The Following 2 Users Say Thank You to PeeBee For This Useful Post:
MudRunnerTD (9th July 2018), mudski (9th July 2018)
