Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 44
Thread: Battery woes
  1. #31
    Oct 2010
    Old Bar, NSW
    They can be a bugger to lift in at the best of times,LOL
    Just a reminder to wipe the posts with a green scourer.
    Did it have much crud under the battery ???
    Did you get the same brand as a replacement.??
    Do you grease the terminals? Never know whether to cover the post before fitting the clamp and then cover the lot or not do it at all.
    Macca
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    squirt of crc does the same
  4. The Following User Says Thank You to Sir Roofy For This Useful Post:
    BigRAWesty (5th May 2016)
  5. #33
    You'll find new batteries have a protective coating that needs to be removed,
    I usually squirt a small bit of terminal spray when finished, weather proofs the lot.
    Even Lanotec will work,,,,, great product IMO LOL
  6. The Following User Says Thank You to threedogs For This Useful Post:
    macca (6th May 2016)
  7. #34
    Oct 2010
    Old Bar, NSW
    How did you go @roofy ? Did @Winnie install it and test the engine run volts?
    Macca
  8. #35
    43 Post(s)
    Very unusual for a battery to be a dud, but I don't really know too much about them.
    Concerned it's in the car as suggested, but more than happy to be proven wrong.
    You don't need this!
    I've just had a 120 ah dual purpose one shat itself only 4 months old..
    It just started self draining and in the end nothing would bring it up in charge..
    Got it replaced and so far it seems good..
    192 Post(s)
    Sounds like good news roofy, Hopefully it was a dud and no more probs now. . .
  10. #37
    TRAFALGAR VIC
    35 Post(s)
    Hope so mate just need to run a good multi metre over it
    to be sure
  11. The Following User Says Thank You to Sir Roofy For This Useful Post:
    Rossco (6th May 2016)
  12. #38
    TRAFALGAR VIC
    35 Post(s)
    New battery is in WOW hit the key and nearly threw the motor
    out of the engine bay
  13. The Following 2 Users Say Thank You to Sir Roofy For This Useful Post:
    macca (6th May 2016), Rossco (6th May 2016)
  14. #39
    How many CCA 750 or higher???
  15. #40
    TRAFALGAR VIC
    35 Post(s)
    760 mate-----------
