Page 17 of 32 FirstFirst ... 7151617181927 ... LastLast
Results 161 to 170 of 320
Thread: Garett's ford maverick 1990,
  1. #161
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    got the uhf... from perth arrived lunch time,
    Jan 2015
    19 Post(s)
    uhf is fitted.
    the wife just complained the front doors make too much noise and a too hard to move. anyone say new door hinges :P
  4. #163
    Jan 2015
    19 Post(s)
    swapped the old 100 w hella's for a aurora style 20" light bar.
    trying out a thing similar to g70. but a ceramic not ptfe.
  5. #164
    Apr 2016
    nice work!
  6. #165
    Jan 2015
    19 Post(s)
    IMG_20170719_180535.jpg yep a nissan clutch in my ford. over 500 000km on that one.
    IMG_20170719_181442.jpg box and transfer out.
    IMG_20170719_180416.jpg new bits ready for the box.
  7. #166
    Jan 2015
    19 Post(s)
    been a little while since i've done much on the mav, knocked up a box for the sub and a couple speakers with an amp to go under the back seat. just need a couple bits and i can fit it in.
  8. The Following User Says Thank You to garett For This Useful Post:
    AB (17th November 2017)
  9. #167
    Jan 2015
    19 Post(s)
    got the box wired up well nearly. but i do have doof doof. will be running 6 speakers and a sub. might even drown out that annoying noise in the back seat...
  10. The Following User Says Thank You to garett For This Useful Post:
    NissanGQ4.2 (24th November 2017)
  11. #168
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by garett View Post
    So instead of rocking the kid 2 sleep your going 2 doof doof it 2 sleep
  12. #169
    Jan 2015
    19 Post(s)
    found the bash plate under the fuel tank was loose. that bolt came out got cleaned up and locktited then tightened till it held everything from moving. this required one foot on the rear bar using a short breaker bar....
  13. The Following 2 Users Say Thank You to garett For This Useful Post:
    Majestic (22nd January 2018), rusty_nail (22nd January 2018)
  14. #170
    Jan 2015
    19 Post(s)
    got around to replacing the bailey channel. in the drivers door. just need to trim the door card to fit speaker surround. and i should be done pulling it apart till i do hinges
  15. The Following User Says Thank You to garett For This Useful Post:
    Rossco (10th February 2018)
