6th December 2017, 07:36 PM
SkippyGU
Td42 rebuild
hey guys i have aquestion for you all which has confused a lot of people.
so let me give you a bit of a rundown on what is happening. So the patrol currently has a zd30 hand grenade 4 speed auto in it. what i have gone out and bought is a TD42 NA diesel motor and 5 speed manual gearbox out of a 1988 gq wagon.
Now the tough part. if i am rebuilding the motor as a turbo motor and i am replacing all the internal parts etc should i be buying parts for a TD42T or a TD42 NA. and with the gearbox i know they need a bit of persuasion and a but of work to get them to fit but thats ok. should i be buying a master cylinder for a gu or gq.
Please shed all knowledge you may have as all will be greatly appreciated
cheers
jack
Currently own a ZD30 2000 GU patrol with a dead injector pump
about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
6th December 2017 07:36 PM
6th December 2017, 07:53 PM
Administrator
Hey mate I guess the first question is what kind of power and why are you chasing big figures to warrant rebuilding the motor?
Or does the motor you are getting need a rebuild regardless?
What year motor did you get too mate?
6th December 2017, 08:35 PM
SkippyGU
the motor needs rebuilding regardless but i thought while im at it i thought i would turbo the motor
mainly chasing big torque for towing heavy trailers for work and play
88 the motor is
The Following User Says Thank You to JackCollo For This Useful Post:
6th December 2017, 10:09 PM
Smart like tractor
96 GQ coil/Cab
08 G6eT
7th December 2017, 06:20 PM
Administrator
Beneboy and Matty are your blokes Jack for internals, let Benny know what you want to spend and keep asking questions mate!
7th December 2017, 10:05 PM
SkippyGU
To be perfectly honest with you all gents the sky is the limit. I’m being dead serious. This is my pride and joy and I’m not gonna penny pinch.
8th December 2017, 06:38 PM
Smart like tractor
First thing is what is actually wrong with the original motor? This could determine what else needs replacement and the cost of machining.
Sky is the minit ay? Well then.
Genuine pistons are a must. Izumi/Mahle brand
Seeing as you have a silvertop, you'll have 28mm pins. You'll have to source some rods to suit turbo pistons
There are stroker kits to 4.5L available from UFI , but I do not know if they are based on a turbo or NA crank, you'll have to find that out
Engine balance is a must!
New harmonic balancer is a must! I have heard that ufi have been working on a viscous damper. I dont know if they are comercially available
Genuine liners. Some aftermarket liners have a step at the bottom of the liner. These are shit and WILL crack. I have seen that UFI have their own liners too.
Look into multi angle valve grinds. You can ceramic coat the pre comb's, combustion chamber, exhaust valve and runner, pistons, exhaust manifold, turbine housing and dump pipe.
Head studs.
Either lighten the stock flywheel by a few kg's or get an aluminum one. (A Must do)
Factory turbo oil pump is a must.
Get your injectors rekitted, standard crack pressure will do.
Injector pump. Ufi seem to do a nice one, they use a different style of Governor, which is something I have wanted for some time.
Replace bolt on items like water pump, viscous hub etc
Upgrade radiator.
By the time you buy a turbo, intercooler, airbox, snorkle etc plus what has been mentioned about you wont get change from 25 grand, maybe 30 grand with labour and consumables if you are paying someone to do alot of it
Edit. The "must do" things mentioned should be done regardless of what you end up going with.
96 GQ coil/Cab
08 G6eT
The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
AB (8th December 2017), mudski (14th December 2017)
8th December 2017, 06:48 PM
#8
Administrator
Is the sky suddenly a lot lower Jack or is that within budget because I would love to see that build thread mate with pics
The Following 3 Users Say Thank You to AB For This Useful Post:
Ben-e-boy (8th December 2017), GQtdauto (8th December 2017), Winnie (8th December 2017)
8th December 2017, 07:43 PM
#9
We would all love to see that being done .
9th December 2017, 04:47 PM
#10
Smart like tractor
AB
I think he is scared... he won't do it 😛🖕
96 GQ coil/Cab
08 G6eT
The Following User Says Thank You to Ben-e-boy For This Useful Post:
