Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 54
Thread: Michael's V8Y62
  1. #31
    109 Post(s)
    Quote Originally Posted by V8Y62 View Post
    During the last week I have taken some datalogs of Pearl and taken a look at them. HP Tuners does support the VK56 engine but there are a few things within VCM Suite (VCM Editor and VCM Scanner) that are not setup correctly and it is taking a bit of time to find the right settings for our V8 engines. There are many parameters in the gauge screen of VCM Scanner that don't function and they don't function because their settings are wrong. I am slowly working through them and will send a message to HP Tuners so they can update the dongles so that scanning, and then tuning, will be easier.
    Things I have noticed viewing the datalogs are:
    1. Pearl rarely goes over 1600 rpm, with the occasional 3000 rpm foray when overtaking or on cruise control going up a steep hill at 100 kmh (actual not speedo).
    2. Timing is set extremely high at cruise speed, 48-51 degrees btdc is not uncommon in the datalogs which makes me think there is not a lot of room to move with timing to gain more performance and economy.
    3. On decel timing can go as low as -7 degrees (7 degrees atdc) idle timing is around 15 degrees btdc which is fairly normal for modern engines.
    4. STFT runs between 0.2 and 6%. My intent is to try and get it to under 2% across the board.
    5. LTFT on VCM Scanner shows 3 digit numbers, 420 comes up often. I reset it to % and it is hovering about 6% which is way to high.
    6. The MAF is a voltage based MAF. As a comparison GM use Frequency based MAFs so rescaling the MAF, to get the ST and LT FTs back under 2%, is different to what I am used to. What makes it even more difficult is VCM Suite doesn't seem, atm, to have settings for the voltage based MAF. This is my priority at this time.
    7. VCM suite doesn't have many settings for the automatic which I find disappointing. While the auto is great and extremely smooth I am well aware the torque converter locks and unlocks alot. In Toyota 200 series forcing the converter to stay locked for longer and locking earlier saves alot of wear and tear on the trans and helps them to run cooler. While I am not towing it is not much of an issue so I am interested in other peoples experiences when towing.
    EDIT: My FB page for my projects https://www.facebook.com/profile.php?id=100089631151497
    All very interesting mate, but really this sort of stuff is above my head. Of your points above though, a couple of questions:
    Point 1.. I find it hard to believe you drive a VK56 and rarely exceed 1600rpm. The pleasure of hearing that puppy sing at 3-4k rpm is worth the fuel outlay!
    Points 4 & 5: So many things can affect the fuel trim (the long term I suppose is more interesting). But what exactly does the percentage indicate? I.e. what is the 6% figure a reflection of? And why is 6% way too high?
    Point 6: Adjusting the MAF will obviously have a bearing on your fuel trim. Do you know, or is there a factory standard setting, frequency, voltage or whatever? How do you know the MAF is working per design specs?
    Do you have the factory exhaust system still fitted? There are 4 x O2 sensors in the exhaust system. Each side has one located pre-cat and one post-cat. It is my understanding only the pre-cat sensors have the authority to alter fuel trim. The rear sensors are for error coding only. If you have an aftermarket exhaust system installed, and have subsequently altered the O2 sensor offset from the exhaust flow, you could negatively affect the fuel trim via changed sensor configuration from factory design parameters.
    Edit: the aftermarket exhaust system comment really only relates to an aftermarket cat replacement, not a cat-back exhaust replacement. I have aftermarket high-flow cats still in the shed until I pluck up the courage to mess with the O2 sensors!
    Cheers.
    Jun 2023
    I have done 1 1/4 mile drag test and heard the induction roar and exhaust rumble making a beautiful cacophony of ICE noise. I actually took my foot off at about 1/8 mile because the steering felt to loose to continue safely. The steering was one of the things I first noted in this thread and while I am getting used to it I still think it is to light.
    The % indicates what the ECU is doing with regards to fuel, it will either take it out or add more in. Normal petrol, not ethanol blend, has an "optimum" (Stoichometric) AFR (Air Fuel Ratio) of 14.7-1, E10 is 14.08-1, LPG (Propane) is 15.5-1. There is another scale that tuners use called Lambda and it doesn't matter what the fuel is the optimum Lambda is always 1.00. The ECU calculates how much fuel is required based on inputs from the various sensors, with all else (e.g engine is at operating temp, ambient air temps are "normal", intake air temps are "normal", oil temp is at operating temp, etc etc etc) being equal on a MAF system the MAF tells the ECU how much air is going into the engine in grams per second (g/s). The ECU then calculates how much fuel to inject and then gets told by the O2 sensors if it injected the right amount or to much or not enough. The % is an indication of the difference between Lambda 1.00 and what the O2 sensors report back to the ECU and on the new information the ECU "trims" the fuel by the % difference. If the O2 sensors report 0.94 (which is rich) then the ECU needs to remove 6% fuel, if the O2 sensors report 1.06 (which is lean) the ECU needs to add 6% more fuel. Scaling the MAF to get fuel trims to within 2% means changing the reference values (g/s) so that the fuel trim is more accurate to within 2%.
    Brilliant question. So the VK56 has a system that uses MAF and also MAP. When tuning MAF the MAP system must be turned off and vice versa so one does not influence the other during tuning. How do I, personally, know the MAF is working per design specs? If it isn't it would trip a fault code and the dash should alert me to this with the CEL (Check Engine Light). The thing with all this though is manufacturers specs cover a huge range of tolerances, some of these are there for a reason 1 being the catalytic converters require fuel to cycle a couple of percent either side of stoichometric to help the cats burn off and not deteriorate prematurely. Generally 2% variation either side of stoichometric is the maximum required for a cat to work efficiently and have a long service life. If the variation is more than 5% the cats burn up, break down, crumble and block exhaust systems.
    Pearl is bog stock in everyway. As soon as anything is changed on the intake or exhaust of an EFI engine the fuel trims will change, the change may not be much but there will be a change anyway. I am aware of the 4 sensors, most modern cars that are Euro 4 and above spec have 2 sensors per cat. The first is to control the fuel trim and the 2nd is to make sure the cats are functioning as required.
    Actually the greatest effect on an engine from an exhaust system is the increase or reduction of back pressure. Reducing back pressure generally causes an engine to run leaner until the ECU adjusts the LTFT to accommodate the change. My intent with Pearl is to work through all these things in a logical scientific manner so that people can see if the difference a modification makes it worthwhile for performance and/or economy reasons rather than just having a nice sound. I should probably say I have a genuine HDT Commodore and had a genuine 1977 Bandit Trans Am. I love the sound of a V8 at WOT (especially the roar of a Quadrajet at WOT) or even just burbling along (the HDT Commodore has the nicest exhaust note I have ever heard at cruise) but I see young fellas throw on huge systems that are loud yet the engine is no more efficient than a smaller system that costs alot less.
    Michael.
    Vehicle: Pearl: 2019 Y62 Ti.
    Modifications: none yet.
    Michael Built FB page
    Hacking the VK56VD ROM thread and GitHub page.
  4. The Following 2 Users Say Thank You to V8Y62 For This Useful Post:
    MudRunnerTD (10th July 2023), Plasnart (25th June 2023)
  5. #33
    109 Post(s)
    Great stuff Michael. Really, really interesting what you're doing. Looking forward to further updates.
    And yes for what it's worth I also (along with nearly every other Y62 review I've read or watched) think the steering is far too light at cruising speed.
  6. #34
    Apr 2021
    Brazil
    This topic is undoubtedly interesting but show us picture addicts some of your Y62 pictures pleeease!
  7. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    MB (30th June 2023)
  8. #35
    Jun 2023
    I apologise for my artistic tardiness. I have 2 weeks holiday coming up and will try to upload a couple of pics of Pearl in her raw stock as a rock beauty.
    Michael.
  9. The Following 2 Users Say Thank You to V8Y62 For This Useful Post:
    BrazilianY60 (27th June 2023), MB (27th June 2023)
  10. #36
    472 Post(s)
    Safe Travels Mick Brother
    Pictures Later Pretty Please
  11. The Following User Says Thank You to MB For This Useful Post:
    V8Y62 (29th June 2023)
  12. #37
    Jun 2023
    Thanks for the well wishes @MB I'm staying home this holiday so I can work on various projects including Pearl. Actually I haven't had an "away" holiday for 17 years, last time I went away was to 1770 in QLD and did some 4wding around K'gari (Fraser Island), 1770, and Bundaberg.
    Michael.
  13. The Following User Says Thank You to V8Y62 For This Useful Post:
    MB (30th June 2023)
  14. #38
    Jun 2023
    Ladies and Gentlemen please let me introduce Pearl, my gorgeous Y62.
    20230707_151316.jpg20230707_151342.jpg20230707_151405.jpg20230707_151438.jpg20230707_151501.jpg
    I did promise pics and here they are.
    To say I love this car is an understatement
    Today I created a Google Sheets fuel economy spreadsheet. I have filled Pearl twice and fuel economy works out at 14.7 (approx) litres/100km, 19 (approx) MPG, and 6.7-6.8 (approx) km/litre.
    I have create a few wish lists / shopping carts on KO gear, Dash Offroad, and a few other online shops. I don;t get paid for another 4 weeks so I'm getting ready for when I have regualr income again.
    Michael.
  15. The Following 5 Users Say Thank You to V8Y62 For This Useful Post:
    BrazilianY60 (7th July 2023), MB (9th July 2023), MB TD42 (19th July 2023), MudRunnerTD (10th July 2023), Plasnart (7th July 2023)
  16. #39
    Apr 2021
    Brazil
    What a good looking Patrol mate, congratulations!
    The bullbar fits it really nice. OL brand? I will have to look that up.
    Were the taillights like this from the factory? Looks like those fancy "euro-style" upgrades.
    Found a Nissan Armada with that V8 on a wrecker over here and started wondering it that would fit a GQ or GU, LOL. But the asking price made me stop wonder, thankfully!
  17. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    V8Y62 (8th July 2023)
  18. #40
    Jun 2023
    OL stands for Opposite Lock. https://oppositelock.com.au/ol/
    Yes they are actually factory. I don't know why but I never liked them, actually I never like the rear of the Y62, until I bought Pearl.
    Brand new crate engines are approximately AU$14K depending on who you buy them from over here. I don't know how much wreckers are charging for them but it wouldn't be cheap. I'd like to eventually get a set of cylinder heads and do some testing on them to see what they flow.
    Michael.
