26th March 2018, 10:11 AM
I am he, fear me
GeeYou8
What is the significance of the yellow band on the tacho between 1600 & 2600?
Graham
Recommended operating RPM power band for torque of a TD42 engine
26th March 2018 10:11 AM
26th March 2018, 09:18 PM
GeeYou8
Graham
I think it is the recommended rang of rpm for the gear changes
26th March 2018, 09:28 PM
Thanks for your response guys sorry I didn't get back to you sooner I have been flat out and the picture up the top is my cluster and mine is a series 2 cluster dash and I have learnt to shift down going up the hills and not labour it so that has brought the temp down a bit and I have learnt that it is about the normal temp rang to run half way to two thirds up the dash depending on load, but to my understanding three quaters would be to high
29th March 2018, 11:20 AM
First Pooy
Honestly if you just bought the car and not sure of condition.
Buy a new radiator and fan clutch . Redo the thermostat too. If you have enough then do water pump
Just a piece of mind.
Dumping coolant and refilling seldom does help with the radiator.
If you want to use that radiator then take it out and take to a radiator shop. The will undo the end tanks
rod each tube clean then reseal end tanks. That's when you say Radiator is like new.
