Page 442 of 564 FirstFirst ... 342392432440441442443444452492542 ... LastLast
Results 4,411 to 4,420 of 5640
  1. #4411
    461 Post(s)
    Will take yours for spin after fitting to see/feel what all the fuss is about.
    Whenever fitting them let us know if need hand. Same as the bar.
    Thanks. I have a big list of stuff to fit to both Patrol and Jayco. I need to eject the wife car out of the garage for a while again I think.
    461 Post(s)
    Pair of Roadsafe HD lower control arms arrived today, along with new bolts from Patrol a Part. HD adjustable panhards next
    Keep the old bolts in the car as spares mate. On a Licola trip Sprock and I did last year he managed to lose a bolt, one of the real long ones too on a track. We eventually found it a few hundred metre back but had to pillage my Patrol for the right sized nut to secure it back in.
    I am really not sure how we would have gotten him out if we didn't find that bolt.
  4. #4413
    194 Post(s)
    Funny you should say that as I purchased the new bolts from Patrol a Part and they seemed expensive until I tried to get a spare set using commercially avail stock from a bolt supplier. The PAP factory genuine units are half the price of the generic ones. I have since purchased a pair for spares from PAP. Unfortunately I will have to destroy the drivers side front/long bolt as the belly tank is nestled right up and past the bolt in the direction it needs to be pulled out. I am not dropping the tank to get it out, so the angle grinder will take the head off and simply reverse the installation so bolt comes in from the outside to the nut. I think @AB and @Rossco went this path also when they mounted their tanks.
    In case anyone does go the external supply route, you need M14 x 90mm and M14 x 180mm long bolts and the respective nuts.
  5. #4414
    You will have to cut a few mm off the new bolt when installing the other way around too mate. I had to remove that bolt over the weekend too and had to take off my rock slider to get it out but that is a lot easier than dropping the tank.
  6. #4415
    194 Post(s)
    Thanks Winnie, alway good to get a heads up and not have to backtrack. Where are you up to with the conversion?
    Winnie (12th September 2018)
  8. #4416
    Let's not go there! Had a stoush of bad luck and keep losing days.
    Rear diff is under the car, just waiting on new seals so I can put the axles in and drop the rear off the jack stands so I can lift the front and get started there.
  9. #4417
    Beginner swathe's Avatar
    Aug 2018
    Rockhampton, QLD
    Baintech 12 way fuse block
  10. #4418
    A series 4 Y62 Ti...
    Drove past a Dealer on Monday and saw it with a price that said "Stop E.T. STOP, you have to come in and buy me!!!"... so I did.
    Me likee velly much, me love long time !!!
  11. The Following 10 Users Say Thank You to the evil twin For This Useful Post:
    AB (12th September 2018), Clunk (12th September 2018), Hodge (12th September 2018), MB (12th September 2018), mudski (12th September 2018), PeeBee (12th September 2018), Rossco (12th September 2018), Touses (12th September 2018), TPC (12th September 2018), Winnie (12th September 2018)
  12. #4419
    Love your work mate. When do you take delivery?
  13. #4420
    I think the missus has been reading about Peebees exploits.
    We're now the proud owners of 4 new cushions. I'm soooooo excited my heads gone all dizzy
  14. The Following 3 Users Say Thank You to Clunk For This Useful Post:
    MB (12th September 2018), PeeBee (13th September 2018), Rossco (12th September 2018)
