Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Limp mode ??
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Im gonna go out on a limb and say I reckon the intercooler is leaking, being the original from 2004, unless its a fairly new OEM unit, it will be leaking. Also, I'd advise to run a needle valve with the Tilix. This will enable you to control the spool up of the turbo, as sometimes a too fast spool up will trigger false positive overboost limp mode, which could be happening with no needle valve.
    So things I would do from here if it were me would be to remove the intercooler and get it pressure tested. If it passes then great, I'd be really surprised if it does. The OEM coolers are known for leaking, even from near new CRD models. Then I would get some MAF sensor cleaner and give it a clean, if you know someone who also has a 3ltr Direct injection Patrol ask to use their MAF for testing purposes. And then put in a needle valve.
    Having said all this, it could be fuel related. Blocked filter, air leaking in, or fuel out. You can buy a cheap scan gauge from just about anywhere now, plug this in and when you hit limp mode you should get an error code, then you can see what is causing this..
    Has not been a lot of info forthcoming.....
    Mark, interested re: your 180RWKW, what N-m are you getting and from rpm?
    you must be pleased with new eng mate.
    461 Post(s)
    Tbh mate. I cannot remember. I took pics of the. Report on my old phone. That does and took maybe 700 photos with it that were on a separate sd card. I should have backed the card up to online storage but I didn’t so I lost a lot on that phone.
    But yeah I am happy. It does have its niggles but overall I love it.
  4. #13
    Jul 2017
    37 Post(s)
    All good, just fitted procharge stage 3 turbo to CRD, need to sort low down torque more, been playing with actuator rod length for quicker spin low down. Do tune for more fuel as well next week, Max B 23psi good run and improving numbers (140-150 rwkw/374N-m), to be confirmed next week. Moves out >2300rpm.
  5. #14
    May 2018
    [QUOTE=Bidja;760090]Has not been a lot of info forthcoming.....
    Thanks fellas I’ll get onto that ASAP and let you know how I go 👍 cheers
  6. #15
    461 Post(s)
    Just fit a needle valve then it only takes about ten seconds and you have adjusted the turbo spool up. 140rwkw are pretty big numbers for a 3ltr. Be careful. I think my old Di was around 125rwkw before the pump shat itself. But I do know not that when towing, the TD just pulls like a freight train and I rarely need to change out of 5th. Different story with the Di...
  7. #16
    Jul 2017
    37 Post(s)
    Yeh, have full manual boost control, last yr actually got dawes and needle of you. Now trialing Tillix (both good kit). The main deal with the Procharge stage 3 turbo is that it has larger 10 blade exhaust whl that take a bit to spin up. Reason for actuator adjustment is to hold veins closed longer low down to get it to spin up earlier to bring on boost (even @ max spool), and also looking at extra fuel low down to help out (ECPT Tuggerah, NSW will dyno tune). Run full NADS, 3" Xpipe, ECU remap, TIG I/C, 3" Fabwitz induction, Gauges boost/EGT/Oil Press. Some CRD produce 200rwhp/25 psi max B but not going there..
    Your torque low down would be a delight.
