Page 3 of 105 FirstFirst 123451353103 ... LastLast
Results 21 to 30 of 1047
    Plasma cutter.. I'll chuck up a picture next time I'm out looking at it. The thing is brilliant. So much less time on the grinder.
    Pair that with a tig welder and it makes whipping up little brackets and mounts easy.
    Ive often wondered about the plasma cutters, I saw one at aldi for 299, but thought I wouldn't use it enough. I have the small makita bandsaw which is fantastic for making precise cold metal cuts doesn't leave sharp burrs the need grinding too. Amazing tool
  2. The Following 2 Users Say Thank You to rusty_nail For This Useful Post:
    0-TJ-0 (23rd June 2019), MudRunnerTD (22nd June 2019)
    22 Post(s)
    I need to buy buy a decent pressure washer.
    My last big purchace was a Cembre hydraulic cable crimper. I can now crimp cables up to 400mm2
    But I'm really looking at a decent lathe and a milling machine.
    96 GQ coil/Cab
    08 G6eT
  5. #23
    I picked up a petrol pressure washer at a garage sale recently, and has far more balls than any electric washer I've ever owned. It's only rated at 3200psi but it does blow well. Can't think of the brand name right now, but it's an aussie made job, with a Honda motor to drive it. Another benefit of it is I can plug in to my water tank which only has gravity pressure and it will self prime and suck the water through the motor without any performance loss.
    I think @MudRunnerTD has a spit water tho, that thing is amazing
  6. #24
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Portable Alaskan-Mill we scored off Gumtree for $1k including the MS660 Stihl is a ripper!
    You got a link 2 a video of this thing cutting MB? Would love 2 see it in action
  7. #25
    Aug 2010
    17 Post(s)
    Want 2 buy list in no particular order
    Plasmer Cutter..... Laser Cutter..... CNC Machine
    Slide Compound Saw
    TIG Welder
    MIG Welder
    Nail Gun
    Air Compressor
    Does a 3D printer come in under Tools???
    The list is endless, and after everything on the list was purchased ( never happen ) I'd need 2 move house with a decent size work shed. Might head over 2 the depression thread now
  8. #26
    472 Post(s)
    Will try to remember for you next cuts needed Toddstar!
  9. The Following User Says Thank You to MB For This Useful Post:
    NissanGQ4.2 (22nd June 2019)
  10. #27
    472 Post(s)
    Pressure washer wise, we’re saving like crazy for the new Stihl 4,200psi with power head for stripping off stubborn bark on logs.
    https://m.stihl.com.au/STIHL-Product...45/RB-800.aspx
    Were kindly lent a demo model to test and crikey it’s a commercial use weapon of a thing!
    I believe once psi on pressure washers goes above 4,500psi a licence or some user certification might be needed hence while Stihl kept it under that Nanny number?
  11. The Following User Says Thank You to MB For This Useful Post:
    rusty_nail (22nd June 2019)
  12. #28
    472 Post(s)
    Best tool ever for hiding sneaky bolognese vegetables for fussy nieces & nephews on cousin madhouse sleepovers :-)
  13. #29
    I was in the local Sydney Tools today Nicco and checked our your new sliding compound saw mate. I nearly got a hard on!!! Farking nice bit of kit.!!
    20 years ago I had my own cabinet making business employing 20. At the time there was no test and tag requirements and 18v was not really in existence. Some 12v and 14v but really only a drill.
    In my shed under blankets I have a full workshop of tools. I sold my thicknesser and vertical spindle moulder, 1 of my router tables and one of my sliding compound saws.
    I have my 18v Makita kit but even that was bought before brushless technology. I have been off the tools for over 15 years and cant justify big purchases for kit I rarely use and no tax break for it these days either.
    I have a Vertical Spindle Sander and a 24" drum sander under a blanket. A 14" band saw, scroll saw, table saw, compound saw, router table, linisher, drill press, stuff. Lol.
    I really like that 18v band saw a lot. I wouldn't mind something to cut steel more than just the cut off saw.
    18v blower is pretty bloody sweet. Favourite kit is probably the simple impact driver cause Tek Screws ROCK and the 1/2 inch rattle is pretty sweet too.,
  14. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  15. #30
    probably the most versatile and useful in a sense that there have been so many uses that i never would have thought of, many others on the forum can attest to this too, an 18V blower. i have inflated matresses, cleaned out sheds, got wet and cold fires roaring with my makita 18V, and i know others have other brands with similar amazement.
    I use one of those 12v mattress blowers a bit of heater hose as an adapter and 3ft of tintanium tube [3/4"]
    like yours works a treat.
    As for tools I had an opportunity to buys some tools so I did
    but cant bring myself to throw the old ones out, Best tools
    are a full set of rachette ring spanners, love em
