25th November 2013, 01:30 AM
25th November 2013 01:30 AM
25th November 2013, 01:54 AM
Hardcore
The only problem is that stuff is for the "inside" of buildings where it is dry, You know that when it rains or you wash your car, it is normal that water travels into the door cavity, the foam will absorb and hold water dirt etc.
BTW, you will also get a much better result, if you dynamat over the huge holes on the "inner" door skin
25th November 2013, 04:02 AM
Mate the only problem here is that all the Technical PDF's for this product and the Ten year world wide warranty disagree with your "opinion" The foam has been pacifically designed not to absorb but to reply water and why I left a 10mm cap between the foam and the normal drains.
The polyether foam used in the manufacture of Soundlag products is non-
fibrous, will withstand the effects of moisture (hydrolysis resistant),
Applications
Hydraulic and waste pipes in all locations
Air-conditioning ducting and shrouds
Compressor wraps
Spa motor wraps
Here's the thread I mentioned in the pm.
http://www.nissanpatrol.com.au/forum...d.php?p=439470
We have found the doing mass dynomat is a waste as you'll see in some of the vids about it, so what you have done there is probably nearly 100%.
Do you plan on doing more than just the doors??
25th November 2013, 05:29 AM
Probally just the floor to firewall in the front don't forget my patrol is setup different. Its done wonders for the audio side.
And back to the comment about water flowing thru your doors with all that sand. If you take the time to look at the inside of the door you can see how the water is channeled it runs around the edges. The doors them self feel different structurally they close with a nice thud.
All this happened because I had to fix one of the winders so i said right why I am in there might as do this one door. Went for a drive loved it so much I kept going on them.
The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
BigRAWesty (25th November 2013)
25th November 2013, 06:03 AM
Hey at the end of the I've been toying with the idea for a few weeks in terms of getting to know the product and it ticks every box except the one where it says may be used on cars. It just made hell of lot more sense to myself to create the sound barrier starting behind door skin itself. I will also be changing the thermal transfer. Same way when you sheet a tin roof you lay insulation with a foil back under the sheet. Be nice if we could have a way of testing but a test that everyone can do so we can get some kind of data not just out there opinion.
25th November 2013, 06:30 AM
What's the plan for the wall. Going to try that stuff or opt for something thinner??
25th November 2013, 08:59 AM
Hardcore
sil3nt_dr3ams
Not sure what info you have, but the tech sheet suggests its just everyday "acoustic foam" sprayed with fire retardent to meet the building code ?
"loaded polymer adhered to acoustic foam with an outer layer of reinforced aluminium foil"
http://www.ecowiseinsulation.com.au/...20Brochure.pdf
Westy's Accessories
Dynamat on both the inner skin, and the inside of the outer skin will drastically improve your speaker/sound system acoustics, without getting right into it, its basically turns the door into a sealed enclosure, and makes the speaker enclosure behave more like its made from a dense material (such as wood)
You can test it yourself, (as i have done) do both skins of "one" door only, then fit the exact same speaker in each opposing door, run a mono signal (so both speaker get the same signal), you will hear a decent improvement in low end responce (its well worth doing)
25th November 2013, 09:16 AM
The 747
Do you completely cover the outer skin? When I do my speakers I will go to the effort because I've seen what a difference it makes.
25th November 2013, 12:24 PM
04OFF
If thats what your going for outta the project then yes, for sure that's the way to go.
But we're trying to achieve sound dampening and reducing outcome its well documented that you only need to cover 25% of the panel you want to apply it to.
Dynamat dampens the panels vibrations not actually reduce the noise itself..
The application or 100% coverage of areas with dynamat has come about from the auto industry, but has been proven that Its not needed to achieve sound dampening..
