21st February 2018, 12:20 AM
patrol y61
Hello everyone .
I have a nissan patrol y61, 2003
When I press the accelerator, the orange light on the A / T button is on the middle panel.
It also seems that the vehicle is not responding well.
Does anyone have any advice?
21st February 2018 12:20 AM
21st February 2018, 01:04 AM
mine does the same.means ya got the power on...mine's a 20120 n a slug,,the 3 ltr wheezer thing...get use to it
and welcome..
21st February 2018, 01:08 AM
I did not understand you, my friend
21st February 2018, 09:08 AM
davidorit
Not many people do understand AVO let me try and interpret for the sand groper .
The three litre does suffer from asthma a bit especially when under load so it's not too bad stock tyres and not loaded up but after that performance drops a bit .
As for the AT light , check the switch is not on the power setting .
21st February 2018, 10:28 AM
davidorit
Mine a 08 CRD (manual) and had similar response / pwr problem. IMO, consider getting things happening with a good tune, have your ECU remapped and you will achieve improved performance and be able to run higher max boost up around 20psi (no limp) along with the bonus of running lower EGTs. Check out ECPT Tuggerah.
